Dell Latitude 7400 EDC40 LA-G871P
  • n_pac
    • Feb 2023
    • 8
    • Albania
    Re: Dell Latitude 7400 EDC40 LA-G871P
    Can anyone help me to unlock this bios?
    Service TAG is: 77KML63
    Thanks in advance!
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      Thanks in advance!
      Become a Badcaps supporter
      Thanks to all supporters.​
      • n_pac
        • Feb 2023
        • 8
        • Albania
        Originally posted by Vesko356
        I have a last question if you don't mind!
        Is it going to be a problem if I do a Bios Update via Windows, to the latest version after the installation of this unlocked version?
        Thank you very much Vesko356!
        Cheers
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Cheers
          No, it won't be a problem, you can update to any version you want, including the latest one.
          • n_pac
            • Feb 2023
            • 8
            • Albania
            Vesko, an error occurred during update! I haven't wrote the service tag that had before!
            What you think, what might be the problem?
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #26
              The error is shown on the screen - invalid password. You must input the correct (bios) password, or better remove the password, then update the bios. If you like afterwards you can set the admin password again.
              I didn't get that, explain what you mean.
              • n_pac
                • Feb 2023
                • 8
                • Albania
                #27
                After the Bios Unlock I've asked you if I could update bios version afterwards to the latest one... You said yes there would be no problem and after that I have downloaded the latest one and during update process, it gave me that error! Isn't supposed to be without password?!
                What do you suggest to do?
                I was wondering if it's necessary to put the service tag that had before which might explain why it gave me that error!
                Once again thanks in advance
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #28
                  Enter the bios, remove the password if you set any, if you didn't set the password everything should be OK (admin password must be cleared with the unlocked bios), check the Service Tag field - must not be empty, if it is ,the STag must be inputted and saved.
                  At first boot press F2, write the service tag, save & restart. After that at the second boot press Alt+F to exit manufacturing mode. And the fan will slow down.
                  • n_pac
                    • Feb 2023
                    • 8
                    • Albania
                    #29
                    Thank you Big Man! Thank you so much!
                    • TuanTongbadcaps
                      • Mar 2023
                      • 64
                      • VietNam
                      #30
                      Hi everybody. Please help me BIOS has late display problem. I have worked with FIT but the problem has not improved. I have flashed many other dump files but not working. With other LA-g871P systems FIT works perfectly.
                      • florenz
                        • Apr 2018
                        • 43
                        • Cameroon
                        #31
                        Hello i just received the Dell Latitude 7400 with a password.
                        i tried it with the bios.bin you posted. it goes well , i edit the same service tag that was there before , i came out of manufacturing mode.
                        after a half hour of test; sometimes the pc get froze .
                        ii want handle it , have i done something wrong by editing the same service tag?
                        allow me please to upload my own backup (with password )
                        thx u so much
                        • aldopc
                          • Jul 2017
                          • 465
                          • Chilito
                          #32
                          thx u so much
                          Hello here is your unlocked file, always use your original dump to avoid any problems.
                          • rizu047
                            • Jul 2021
                            • Pakistan
                            #33
                            remove password please Dell Latitude 7400 EDC40 LA-G871P
                            • desoba1650
                              • May 2023
                              • Baku
                              #34
                              Hello, can you help me please, I need to reset the bios password
                              Bios link
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #35
                                Bios link
                                Read the rules before posting:
                                You must attach files directly to your post instead of linking to external websites.
                                • lapfix
                                  • Mar 2020
                                  • 2730
                                  • my workshop
                                  #36
                                  1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.Good luck.
                                  All donations to badcaps are welcome,see the donate button at the bottom of the page,or click on this link to donate via PayPal. Every donation made will go towards server fees and maintenance costs.
                                  • rizu047
                                    • Jul 2021
                                    • Pakistan
                                    #37
                                    thanks Man...Lapfix
                                    • florenz
                                      • Apr 2018
                                      • 43
                                      • Cameroon
                                      #38
                                      Originally posted by aldopc
                                      hello here is your unlocked file, always use your original dump to avoid any problems.
                                      thx you my dear . And i took note of the advise. Otherwise i flash the new bin it works goods but the laptop is frozen when i tried to boot an os...
                                      May be didnt respect the process ?
                                      I flashed the bin ? Soldering back , start the pc , and put back the service tag.
                                      Please i need help
                                      • aldopc
                                        • Jul 2017
                                        • 465
                                        • Chilito
                                        #39
                                        Please i need help
                                        Ok, try this file follow these steps: 1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode and comments.
                                        • florenz
                                          • Apr 2018
                                          • 43
                                          • Cameroon
                                          #40
                                          Hello Sir , i did it !
                                          unfortunely is still freezing...
                                          i respect the process very carefully.
                                          what can i do ?
                                            DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 12:36 PM
                                            DELL Latitude 7400 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7400 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
