Hometech htbook14 bios dump
  • Guilty_2121
    • Jan 2021
    • 43
    • Türkiye
    hello everyone
    i need bios for laptop. it's a baytrail cpu.
    motherboard model
    I5-3735-B2
    V3 2016-05-04
    Added dump bios maybe some clear it or check it's broken or not.
    Also look like same laptop with this one:
    4good Light AM500
    • 20481
    Re: Hometech htbook14 bios dump
    https://www.badcaps.net/forum/showthread.php?t=69015
    • Guilty_2121
      • Jan 2021
      • 43
      • Türkiye
      I look for this thread and 4good links is not working and thomson bios is not same size with mine
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • grimacelord
        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
        by grimacelord
        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
        Motherboard model number: DA0PAMB46A1 REV: A
        Secondary motherboard model number: 0PAB
        SKU: 685K4UA
        Serial number is: 5CD3223BJP
        Recently reflashed this laptop with latest BIOS and once...
        05-07-2024, 08:06 AM
      • DynaxSC
        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
        by DynaxSC
        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
        11-06-2022, 05:22 PM
      • TacticalFahrrad
        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
        by TacticalFahrrad
        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
        06-30-2025, 04:09 AM
