Asus X415EA bios file needed
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Hi everyone. I've got a laptop that was brought to me with water damage. Board is beyond repair coz of the burnt marks that penetrated the pcb.
    The owner bought a replacement motherboard online but he did not notice that there is no bios chip on it. I try to salvage bios chip from the damaged board but two of my programmers were unable to read and extract data from it.
    I ordered chip and will arrive tomorrow. Does anyone have a bios dump on this one? Motherboard code is X415EA R2.0, laptop model is Asus X415 core i3 version. chip model is gd25b127d. Hope someone has. Thanks
    • 20898
    Re: Asus X415 bios file needed
    What model is your programmer.Are both boards exactly the same.Are there any barcode stickers near the ram slots,or square white QR codes on the motherboard
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      I got TL866II Plus and RT809F. And yes they are identical.
      • lezsimply
        The Wanderer
        • 645
        • Philippines
        There is no QR code i can find. I attached motherboard image
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          Hi, I got the bios chip i ordered which is the same model from the defective board. It was not brand new and I was also surprise it has data on it. Tried to use that chip as is and board powered on but it has no display. I attached bios file extracted from new chip.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11736
            Try this file. I got it in internet.
            • lezsimply
              The Wanderer
              • 645
              • Philippines
              Thanks. I will try to compoare first. X415 is an i3 version while X515 is i7. Thanks
              • Repdata
                • May 2020
                • 67
                • Deutschland
                checking
                • lezsimply
                  The Wanderer
                  • 645
                  • Philippines
                  @Repdata Unfortunately its not working. The system does not power on with that bin. But thanks.
                  However bios file i recently uploaded turns on the laptop but there is no display. The fans seems to throttle when cpu heats up. Hope someone has fix for bios or any dump file same as the board code mentioned. Thanks.
                  • lezsimply
                    The Wanderer
                    • 645
                    • Philippines
                    Just an update. The file given by hoaca388 from comment number 6 worked. Although the nvme drive is not being detected. Some say bios could still be the issue. I have very little knowledge of these newer systems unlike the older systems. I guess i am outdated
                      • 20898
                      Can you check for a QR code under the wifi card
                      • lezsimply
                        The Wanderer
                        • 645
                        • Philippines
                        Hi, there is no qr code under the wifi card. As for the whole board, this is the only one i found though it doesnt point me to any website. There are qr codes on other components such as speaker, battery pack and the casing itself.
                        • lezsimply
                          The Wanderer
                          • 645
                          • Philippines
                          This is laptops complete model: P1411CEA-EB838T
                            • 20898
                            The QR code,and barcode on other boards identify which bios the board has https://www.badcaps.net/forum/showthread.php?t=96604 . So,now you found the QR we know you need a X415EA working bios
                              • 20898
                              Try this one .
                              • lezsimply
                                The Wanderer
                                • 645
                                • Philippines
                                Good day to all, sorry i was not able to get back soon coz i got sick.
                                Anyway, I would like to thank everyone for the help. And also many thanks to SMDFlea for sharing me the file. I can confirm that his bios did the job and I'm now able to detect the nvme drive. So far everything is working fine. Cheers to us!
                                • correoprueba
                                  • May 2022
                                  • México
                                  hi i have an asus x515ea i3 10gen, the motherboard is x415ea r2.0, don't working Asus X515EA - X415EA REV 2.0.bin.zip
                                  • peste
                                    • Dec 2016
                                    • 12806
                                    • ROMANIA
                                    read post # 11,12,14 and post the original bios of the laptop ... if you need bios ..
                                    • wishes2022
                                      • Nov 2022
                                      • 35
                                      • china
                                      Originally posted by SMDFlea
                                      Try this one .
                                      Thank you!
                                      I will try this.
                                      • bios29
                                        • Dec 2018
                                        • 20
                                        • france
                                        hello,
                                        i have an asus x415ea-bv130t which have a bios issue its not detecting the ssd , i tried some bios on the forum and i have one bios who recognize the ssd but no keyboard and other who recognize keyboard but not the ssd
                                        somebody may have a good bios were i can get the ssd and the keyboard would be appreciate
                                        • exerion5000
                                          Bios Needed For Asus X515EA Pcb X415EA R2.0
                                          by exerion5000
                                          Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                          Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                          02-17-2025, 01:34 PM
                                        • wakethesleep1111
                                          Bios File Needed for asus tuf15
                                          by wakethesleep1111
                                          Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                                          05-27-2025, 10:56 PM
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
