HP BIOS unlock tool
  • ferypepa
    • Dec 2021
    • 5
    • España
    #1141
    Re: HP BIOS unlock tool
    Hello everybody !
    This is my first post here.
    Let me tell you my problem, I have a Elitebook 745 G2 with Bios admin password lost and Secure Boot enable, so I have been unable to clear bios using Mazzif method, and just decided try this process.
    Once decided, I would like to ask your help for:
    1-. Any recommendation for CH341A and SOIC8 clip adapter to read and program back my BIOS ?
    I don't have any, so will purchase one that any of you are using successfully ( if possible with a model same as mine Elitebook 745 G2)
    2-. Anybody can help me to identify if the BIOS chip to be read and written back is the one with the blue dot ( red arrow pointing to it) ? As there are two similar chips in the board, I am not sure to which one attack.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #1142
      If you happen to have a raspberry, use that as a programmer, solder wires to chip, flashrom as software.
      Otherwise, random ch341a which has a soic8 adapter in kit. I personally have used the green one but they are all awful anyway. But they do the job mostly.
      Main bios is always biggest (read the numbers on it).
      • Adi13089
        • Oct 2017
        • Polska
        #1143
        Originally posted by peste
        try..
        What is the password on the old file?
        BIOS-administrator? does not fit.
        • cdgold3
          • May 2018
          • 23
          • Cleveland
          #1144
          Hi Guys,
          Trying to unlock bios on a HP ProBook 650 G1 with the HP Unlock tool but unlocked dump is stall password protected.
          Can anyone help or point me in the right direction?
          • cdgold3
            • May 2018
            • 23
            • Cleveland
            #1145
            Originally posted by cdgold3
            Hi Guys,
            Sorted - Using RCUnlocker worked for me
            • ferypepa
              • Dec 2021
              • 5
              • España
              #1146
              Thanks @RetoricalCheese, unfortunately don't have a Raspebrry, so purchased a ch341a kit. I will test it when it arrives.
              The two chips are marked/read as follows: the one with the blue dot is brand Winbond, 25Q64FVSIG 1529, and the other one is also Winbond brand but model 25Q160VSIG 1545.
              From my "google research", I understand that I need to read from ( and later write to) this one 25Q64FVSIG .
              If I am wrong, please let me know.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #1147
                That's right.
                Become a Badcaps supporter
                Thanks to all supporters.
                • MaxJ
                  • Apr 2019
                  • 9
                  Confirmed worked with Elitebook 840 G3, thank you.
                  • duken
                    • Dec 2021
                    • kOF
                    #1149
                    Good evening,
                    I'm the owner of a HP ProBook 4730s. The bios is locked by a lost password.
                    I've dumped the bios with a CH341A Programmer. I've tryed unlocker on post 1 but it's not working despite change inside the unlocked file. On the HP website the Bios is 2.5Mb but the chip (MX25L512C) is only 512kb.. I've tryed some to like UEFITool to make is smaller with no luck.
                    Can you help me to find a way to remove it ? Attached, the original bios file I dumped, the modified (non working file from Unlocker).
                    Thanks a lot.
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #1150
                      Obviously you have the wrong chip. Find the correct one. It might be in a socket on that model.
                      • maxxcomputers
                        • Mar 2015
                        • 9
                        #1151
                        Hi, bios for HP ProBook 645 G2, please, THX.
                        • duken
                          • Dec 2021
                          • kOF
                          #1152
                          Hello RethoricalCheese,
                          Thanks for your time and reply. I dont understand where this chip can be. I've looked around everywhere. I've found some powerchip but nothing programmable or look like a BIOS chip
                          • alfatech
                            • Dec 2021
                            • 7
                            • canada
                            #1153
                            Tested and works on hp probook 430 g3. Note: drag and drop the locked bios onto the program
                            • ofni
                              • Dec 2021
                              • France
                              #1154
                              first of all thank you for this forum and the tools you have developed it is very helpful.
                              I have an HP 840 G1 with the bios locked by a password.
                              I successfully dump the bios (via a CH341a programmer) and unlock the bios via RCunlocker and it is working.
                              But now I have the following message at startup : "Warning!! Machine is not in committed state!"
                              I tried to use wndmifit but it seem the mpm mode is locked too.. and I cannot succeed to unlock with windows touch + up + down
                              Does somebody have a tips or a suggestion to remove this message ?
                              (I do not understand very well why I have this message ..)
                              thank you very much
                              • peste
                                • 13722
                                • ROMANIA
                                #1155
                                thank you very much
                                try this
                                https://www.youtube.com/watch?v=9T57ktw8n3Y
                                • ofni
                                  • Dec 2021
                                  • France
                                  #1156
                                  I would like but the laptop is in mpm LOCKED mode :/
                                  and when I tried to go in unlocked mode with windows touch + arrow down + arrow up + power the laptop start, display HP logo and stop
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    #1157
                                    Random issue. Sometimes bios update gets rid of it.
                                    • ferypepa
                                      • Dec 2021
                                      • 5
                                      • España
                                      #1158
                                      Thanks everybody, unfortunately I was not able to make it.
                                      I received my CH341A programmer yesterday, and spent the afternoon with the clip.
                                      No way I could detect the bios chip ( winbond 25Q64FV). No matter how I put the clip, I could't detect it, not even once.
                                      Reading about the clip problems, I decided to solder.
                                      This time, I was able to detect the chip but readings was garbage, anytime I pressed detect, the chip ID changed.
                                      I could verify just once the dump, but it was also garbage ( same content in blocks), throw that file to RCunloker but, as expected, message that was not ant "unlockeable material".
                                      I think it's a connection issue, but verified the continuity of cables from chip pins to CH341A, and they were correct, double checked several times the layout connections in programmer for 25xxx chips, but couldn't isolate any problem, maybe there is a little short in my solder connections ( I am not an expert ).
                                      So, I surrender .... for now.
                                      Luckily my computer still boots with a W10 disk, and I can use it although not able to access BIOS, change logo,...
                                      I heard about a probe instead of the clip. Not sure if it will perform better or you need to have the pulse of a medical surgeon. I will investigate.
                                        • 22096
                                        Use NeoProgrammer,Colibri or ASProgrammer software instead.Also there`s a 3.3V modification you can make to the programmer to make it a bit more stable,if you have the black PCB version,you`ll find some youtube videos, search for "CH341A 3.3V mod"
                                        • ferypepa
                                          • Dec 2021
                                          • 5
                                          • España
                                          #1160
                                          Thanks SMDFlea,
                                          I will give a try tomorrow to these softwares.
                                          I have the green version of the CH341A, but will double check the voltage it gaves as well.
                                          Read also about, trying to dump with the CMOS battery connected. So, another test.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
