HP BIOS unlock tool
  • peste
    • 13421
    • ROMANIA
    #881
    Re: HP BIOS unlock tool
    Originally posted by newbie_unlocker
    hi everyone i am hoping someone can assist me? i have a hp elitebook 850 g1, i have attched a ch341a using the clip method and according to the ch341a it dumped a file from the winbond chip which is still soldered to the board which the size that was dumped is 2,048kb in size. i saved it as biosold.bin and dragged it into the hpunlocker which then created the biosold_unlocked.bin
    i then flashed this back to the winbond chip and verified the file which matched but the administrator plus other user names in the bios still remains. what could i be doing wrong? and is there anyone who can help me out?
    post the backup of the bios, the original bios of the laptop.
    • newbie_unlocker
      • Jul 2021
      • 17
      • england
      #882
      the biosinfo.bin was dumped from the larger chip and the biosinfo.bin was dumped from the winbond chip hope that helps and thanks for the reply.
      hope you can sort this
      • onlylove17
        • Jun 2021
        • 63
        • VN
        #883
        Originally posted by peste
        try..
        Hi, Bro
        I need Bios 735, 745 g6 original, Can you help me?
        Thanks for sharing
        • peste
          • 13421
          • ROMANIA
          #884
          the 16 MB bios is empty read once more and post again ..
          • peste
            • 13421
            • ROMANIA
            #885
            Originally posted by onlylove17
            Hi, Bro
            Thanks for sharing
            post the full name and model of the laptop and the backup of the bios.
            • newbie_unlocker
              • Jul 2021
              • 17
              • england
              #886
              try this one i have just read it again thanks also i am using asprogrammer v 1.380.
              • peste
                • 13421
                • ROMANIA
                #887
                just as empty..don't use the clip..you give errors..better pull your wires from the bios chip to the programmer ..
                • newbie_unlocker
                  • Jul 2021
                  • 17
                  • england
                  #888
                  can you check this one 1 more time i have changed the as programmer version
                  thanks again
                  • onlylove17
                    • Jun 2021
                    • 63
                    • VN
                    #889
                    HP elitebook 745 g6 (r74)
                    • peste
                      • 13421
                      • ROMANIA
                      #890
                      and the original bios of the laptop ???
                      • peste
                        • 13421
                        • ROMANIA
                        #891
                        thanks again
                        it is not good even now..check with the HxD program the copy you send..enter the copy of your bios and a correct copy of the laptop bios (find on the forum) in the HxD program and make the comparison ..
                        • onlylove17
                          • Jun 2021
                          • 63
                          • VN
                          #892
                          this one
                          • onlylove17
                            • Jun 2021
                            • 63
                            • VN
                            #893
                            this one
                            • peste
                              • 13421
                              • ROMANIA
                              #894
                              this one
                              bios extracted from the HP site update
                              • shiraz77
                                • Oct 2020
                                • 6
                                Hi everyone.
                                In the UEFITool, I am trying to empty my first padding in the BIOS region. After extraction, I use the HxD program and use the "Fill selection" command to replace all data with FF. Next, I replace the padding with the modified file. But for some reason, the file sizes differ and I can not rebuild my bios file due to the size difference.
                                Can anyone guide me on the problem?
                                  • 21679
                                  Originally posted by shiraz77
                                  Hi everyone.
                                  What bios are you working on and from what model.......
                                  • shiraz77
                                    • Oct 2020
                                    • 6
                                    Hi everyone.
                                    Problem fixed, my bad. It is a little tricky modifying padding size.
                                    • shiraz77
                                      • Oct 2020
                                      • 6
                                      Elitebook 840 G6.
                                      It has two bios chips. Would anyone know if I need to clean both of them?
                                      • shiraz77
                                        • Oct 2020
                                        • 6
                                        Elitebook 840 G6.
                                        Any help in unlocking would be appreciated. I have attached the bios files.
                                        • newbie_unlocker
                                          • Jul 2021
                                          • 17
                                          • england
                                          #900
                                          hi everyone, ok I need some help so here goes..I have a hp 850 g1 which has an administrator password and just below that in the bios there are two more users. I have bought a ch341a and I also have the hp unlock.exe..i have desoldered the larger of the two chips that are on the board. I think I may have bought the wrong sop8 chip socket as attached because it's the 150mil version but my bios chip doesn't seem to fit in it causing my ch341a to produce ff and ffff when trying to detec. do I need the 200mil? also the chip I have is 25q128a 13eco 99chn 42005 and is 8 pin what is the more reliable software that will have this chip number in its database that actually works or confirmed working with a hp 850 g1? I have about 300 of these laptops to work on.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
