HP BIOS unlock tool
  • techcare
    • Nov 2017
    • 18
    • KOREA
    #461
    Re: HP BIOS unlock tool
    Working in 6470b?
    • nik nik
      • Dec 2017
      • 20
      • nigeria
      #462
      there is an fatai error message when i try to open it
      'failed to execute script HPunlocker'
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        #463
        Because you did not read first post.
        • leva2407
          • Jul 2016
          • 89
          • tbilisi
          #464
          plaese help me to unlock me hp 745 G4 travolta-6050a2834601-mb
          • lavchyk
            • Dec 2014
            • 9
            • Ukraine
            #465
            try it
            • leva2407
              • Jul 2016
              • 89
              • tbilisi
              #466
              still locked please halp me
              • vpiru1
                • Oct 2020
                • Portugal
                #467
                does the tool clear also the power on password? if not, does anyone know a way to do that?
                • RethoricalCheese
                  • Mar 2013
                  • 1518
                  • Estonia
                  #468
                  Send the file and I shall see.
                  • LVLO
                    • France
                    #469
                    Work great for 820 G3
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      #470
                      Looks like it is time to start programming HPUnlocker_v2. Reason being that I just received these laptops to test on and successfully unlocked G6 without any issues at all. No errors on every boot, no missing SN, OA3 etc and it takes less effort than previous methods.
                      Tested on 840G6, 850G6, 745G6.
                      I don't wish to release this method just yet because I still want to test some things to see if it is a reliable method. Meanwhile, you might want to use previous method, introduced by Peste.
                      And I will ignore every request in personal messages so don't bother sending them
                      • Kilroy2020
                        • Oct 2020
                        • 7
                        Excellent thread and thanks RethoricalCheese! I plan to attempt this on an Elitebook 830-G6 this week and I happen to find this in the nick of time. I realize that you don't have the new v2 version of HPUnlocker, but can you help me confirm what I need to do?
                        I only see one BIOS chip on my board; WINBOND W25Q256JVEN. Is there a second chip that I need to dump and re-program?
                        • RethoricalCheese
                          • Mar 2013
                          • 1518
                          • Estonia
                          #472
                          Yes, starting to write v2 today.
                          And yes, you need the other chip, which is on the other side of the board on 840/850/745. I guess its the same with 830.
                          • Kilroy2020
                            • Oct 2020
                            • 7
                            Thank you very much for the quick reply. If you need a Beta tester for your code, I'm willing to give it a try!
                            Thanks again.
                            • Youyou
                              • Oct 2020
                              • 11
                              • France
                              #474
                              Hi, just to thank you. It works fine with elitebook 820 g1��. After flashing unlocked file i had a small issue with network card, no more connexion whatever drivers i used. I updated the bios and it fixed it. Thanks again
                              • some1
                                • Oct 2020
                                • Portugal
                                #475
                                Hello guys. I just registered because I searched a bit and did not found info regarding this.
                                Have a 840 G5 with bios password that I bought second hand. How can I read the bios and make a dump? Many thanks
                                • AlexKZ
                                  • Oct 2020
                                  • Ukraine
                                  #476
                                  HP Elitebook 850 G2 - work great!
                                  Move it to c:\ before using and disable UAC!
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1518
                                    • Estonia
                                    #477
                                    Does anybody happen to have EC (the smaller sized) bios from a locked Elitebook G3/G4? I've seen G5 and G6, just want to check if previous models are partially the same.
                                    • kitor
                                      • Apr 2019
                                      • 45
                                      • Poland
                                      #478
                                      Thank you for that tool. I can confirm it working succesfully on 840 G3 and 640 G1.
                                      Of course I had to fight with MS Antivirus first...
                                      • mnciks11
                                        • Aug 2019
                                        • 345
                                        • south Africa
                                        #479
                                        Kindly assist with Hp Probook 650 G2 bios locked
                                        file attached below
                                        • Mugatu
                                          • Sep 2020
                                          • 7
                                          • Sweden
                                          #480
                                          Originally posted by RethoricalCheese
                                          Haven't had an issue with surestart yet.
                                          Sorry, I just need to double check. You have successfully removed the password on laptops with Surestart enabled?
                                          So both chips needs to be reprogrammed, right?
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • mohamedbalwe
                                            BIOS FOR DS-7204HQHI OR UNLOCK PASS FOR THIS FILE
                                            by mohamedbalwe
                                            hello everyone
                                            i need bios dvr DS-7204HQHI
                                            motherboard code 80303-p rev 2.2
                                            The attached file is lock pass...
                                            07-14-2025, 06:02 AM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
