Re: Macbook M1 bypass FMM / EFI Unlock
hello ethiogsm
thanks for your return, even with internet recovery does that work ? another question does the workaround also work with Monterey?
This topic is closed.
you just press the key command+T repeteadly in recovery screen while you are at the language selection part.Leave a comment:
hello
I share that yesterday I started to compare the information of my mac M1 unlocked and locked.
I used the hidden menu on the unlocked M1 and found that the preboot drive had 3 files and the locked mac only had 2.
What I see is that the unlocked one has a file called active.
Do you think this is the one in charge of having the pc unlocked, I tried to copy it but I have no way, how do you see? what do you think?
Cheers!Leave a comment:
may i ask you how to open terminal on T2 mac on wich step you did that ? i need your assistance to reproduce it please. i tried to hold cmd+t with no success.
thanks in advance.Leave a comment:
Is that exploit on the old bridgeos?Leave a comment:
hi I have m1 macbook pro max device MDM. I deleted ssd and install new OSX MONTEREY after I said no internet connecting full installed device. I am going to recovery mode
terminal csrutil disable. gives an error message
csrutil: the Os environment doesnt allow changing security configuration options.
Ensure that the system was booted into Recovery OS via the standart user action.
I need help
recovery mode and terminal csrutil disable
bingo worked .
after I paid check_m8 for mdm bypass software. it is working now without MDM.Leave a comment:
There is some guy on youtube showing how he open terminal inside activation window on M1/T2 mac.
keywords: M1 terminal inside Internet recovery MacOS Monterey
How is this possible? We need to find key combination, for the moment found way to open log window / save logs to usb.
ive tried this on M1 but doesnt work.Leave a comment:
I need helpLeave a comment:
hello Mario,
thank your for your reply,
for replacing the ssd nand iam already aware that is soldered to the motherboard, and i didn't say that it will be easy to replace it even more to bypass FMM if the swap is successful.
but i already read that it is possible with the right skills: https://www.google.com/url?sa=t&sour...q4tYb80tIOUmJ_. (link for an article about Chinese upgrading ram and ssd on m1 model)
regards.
hi killeur
If it is what I have seen in the information of all the research reading. I haven't tried it because I don't have the tool and the other one is like hitting the tower if I can't make it work again. But this sure the hard drive has to do with the whole crash. And more as it is designed. Look at this.
https://eclecticlight.co/2021/01/18/...l-and-m1-macs/Leave a comment:
hello Mario,
regards.Leave a comment:
Hello every one,
i want to thank you all for effort and contribution,
I was wondring if any one had tried to replace the ssd nand ships and reset the mac from dfu mode using Apple configurator App ? like replacing a normal ssd would that bypass FMM ? i am new so forgive me if iam saying bullshits.
Regards.
Hi Killeur,
you can't with newer macs, since the hard drive is soldered onto the motherboard.
Hello every one,
Regards.Leave a comment:
Can you share with us how you were able to start in linux?Leave a comment:
I'm working on, i can't find the original mobileactivationd version for understand where they make the patch. But, i have an idea and in the free time i work on python program, i think this can work easy with a macbook just bypassed. So just for proof of t2 can be pwn:
J40aap key latest bridgeos.
IBSS:
IV: 120402A7168E7AAAC1F94C6A5D58F8F1,
key: 5C1E07A0EA5A8F48D09FA568182172CA74880896761CFA6992006558CDD9981D
IBEC:
IV: 6909A0A0D9675B5BAEFB9ECFAA00386C,
key: C7DA39AF1DB80189C27F5D3A39C01F13D4FD7C7B6453DAADE018DC6188BAD24A
About diagnostic i have no idea how you can boot m1n1 with security on. If you wonna make this a bit of sense send me a pvt thanks.Leave a comment:
Hi guys thank you for sharing your findings and questions.
BTW, has anyone managed to install/run a linux or any other OS on a locked M1 MAC PRO? Could you share how you did it?
Thanks.Leave a comment:
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by oxonaterHi everyone hope all are well
I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
I suppose it's worth noting googling the part package brings up various... -
by keats11I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
Channel: BIOS Requests ONLY!
by envymHi everyone!
I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by ManlikeissakHello everyone hope you all are doing well, I'm posting here since no was interested in my post on "MacBook unlocked!" Topic, so In short I have found a way to test every possible key combination to try and find the combination to open the terminal on fmm/EFI locked M1/M2 machines, the person who found this still refuses to give info, but if hasn't lied about it being a key combination there's a chance we might find it, so to try Evey key combination I've got a digispark attiny 85 which is a small μController, I've written as script to emulate a keyboard and go thru every possible key...5 Photos
- Loading...
