Request: Clean-ME from DA0P1GMB6d0 Rev.D
  • lazaro.089
    • Jun 2014
    • 79
    • Mexico
    Hello everyone.
    Can somebody help me with this BIOS.
    When I try to use ME Injector It says:
    "The ME/TXE region in this image has been disabled"
    Tried with other dump and computer boots fine. I just want to clean ME region and leave everything else as is.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11661
    Re: Request: Clean-ME from DA0P1GMB6d0 Rev.D
    Originally posted by lazaro.089
    hello everyone.
    Can somebody help me with this bios.
    When i try to use me injector it says:
    "the me/txe region in this image has been disabled"
    tried with other dump and computer boots fine. I just want to clean me region and leave everything else as is.
    • lazaro.089
      • Jun 2014
      • 79
      • Mexico
      Thank you @hoaca388
      Sadly, it didn't worked. Maybe I'll just try and use the dump that I downloaded from the web and worked.
      I just didn't wanted to configure Serial, Build ID and other HP Stuff (including the Manufacturer Programming mode)
      Thank you again!
        • 20733
        Thank you @hoaca388
        Thank you again!
        Go to the HP support page and download the bios update exe,run the exe and choose to save to a location. All the bios for different models will be decrypted. Look at each bios name and check for those names in your backup using a hex editor. Your bios is corrupted but the name 084D was found,so i assume thats the right one,and if not you can try the others.
        Copy the DMI info, + key from your backup to 084D virgin bios using these offsets
        D 3C7000 - 3CAFFF
        W 3C5000 - 3C503F
        Edit: Never use ME Injector,clean the ME properly using the guide at the win-raid forum https://www.badcaps.net/forum/showthread.php?t=88533
        • sourcebf
          • Jul 2016
          • 431
          • N/A
          Hello everyone.
          try this bro it is your dump
          • slade1
            Dell G15 5510 - Request to clear ME region
            by slade1
            Dell G15 5510, mb: LA-K661P
            Service tag: 77W73G3
            Could someone please help me clean my ME region?
            Original BIOS is stuck on a black screen, i found a new bios, but i have problems with TPM, the boot is extremely slow, and the USB 3.0 port doesn't work...
            11-16-2023, 03:25 PM
          • pziembowski
            Dell Latitude E5270 - Request to clear region me
            by pziembowski
            Dell e5270 mb: ADM60 LA-C621P. I kindly ask you to help me clear my region. On the original black screen, on the second laptop works but without wifi and lan...
            01-04-2023, 09:35 AM
          • slade1
            Dell G15 5510 - Request to clear region ME
            by slade1
            the original BIOS is stuck on a black screen (), I found the BIOS file from another laptop to rewrite (), but clear ME is needed.
            Can someone help me?
            Files:
            11-10-2023, 11:50 AM
          • tom3k
            Dell Precision 5540. Need clean ME Region
            by tom3k
            Laptop: Dell Precision 5540
            MB: LA-H331P Rev: 1.0(A00)
            Hi.
            I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
            After extracting my BIOS in FIT the ME Region size is 7565 KB.
            However the ME Region files I fouud online are 11688 KB in size.
            Can someone help me find he correct clean ME Region?
            Thanks!
            Code:
            ║ Family │ CSE ME ║
            06-28-2025, 12:34 PM
          • shog
            Lenovo Legion Y530 NM-B702 - bios clean region ME request
            by shog
            Model: Lenovo Legion Y530
            Motherboard: NM-B702
            CPU: i5-8300H
            GPU: 1050Ti
            It works, but it takes some time to boot Windows.
            I'm 99% sure bios is the problem, would somebody clean region ME from it? ...
            08-08-2022, 10:43 AM
