Request: Clean-ME from DA0P1GMB6d0 Rev.D
  • lazaro.089
    • Jun 2014
    • 87
    • Mexico
    Hello everyone.
    Can somebody help me with this BIOS.
    When I try to use ME Injector It says:
    "The ME/TXE region in this image has been disabled"
    Tried with other dump and computer boots fine. I just want to clean ME region and leave everything else as is.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Request: Clean-ME from DA0P1GMB6d0 Rev.D
    Originally posted by lazaro.089
    hello everyone.
    Can somebody help me with this bios.
    When i try to use me injector it says:
    "the me/txe region in this image has been disabled"
    tried with other dump and computer boots fine. I just want to clean me region and leave everything else as is.
    • lazaro.089
      • Jun 2014
      • 87
      • Mexico
      Thank you @hoaca388
      Sadly, it didn't worked. Maybe I'll just try and use the dump that I downloaded from the web and worked.
      I just didn't wanted to configure Serial, Build ID and other HP Stuff (including the Manufacturer Programming mode)
      Thank you again!
        • 22279
        Thank you @hoaca388
        Thank you again!
        Go to the HP support page and download the bios update exe,run the exe and choose to save to a location. All the bios for different models will be decrypted. Look at each bios name and check for those names in your backup using a hex editor. Your bios is corrupted but the name 084D was found,so i assume thats the right one,and if not you can try the others.
        Copy the DMI info, + key from your backup to 084D virgin bios using these offsets
        D 3C7000 - 3CAFFF
        W 3C5000 - 3C503F
        Edit: Never use ME Injector,clean the ME properly using the guide at the win-raid forum https://www.badcaps.net/forum/showthread.php?t=88533
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          Hello everyone.
          try this bro it is your dump
          • Destroyer-Br
            [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
            by Destroyer-Br
            I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
            When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
            If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
            After flashing it, the board does not power on — no signs of life.
            I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
            11-23-2025, 02:48 PM
          • slade1
            Dell G15 5510 - Request to clear ME region
            by slade1
            Dell G15 5510, mb: LA-K661P
            Service tag: 77W73G3
            Could someone please help me clean my ME region?
            Original BIOS is stuck on a black screen, i found a new bios, but i have problems with TPM, the boot is extremely slow, and the USB 3.0 port doesn't work...
            11-16-2023, 03:25 PM
          • pziembowski
            Dell Latitude E5270 - Request to clear region me
            by pziembowski
            Dell e5270 mb: ADM60 LA-C621P. I kindly ask you to help me clear my region. On the original black screen, on the second laptop works but without wifi and lan...
            01-04-2023, 09:35 AM
          • slade1
            Dell G15 5510 - Request to clear region ME
            by slade1
            the original BIOS is stuck on a black screen (), I found the BIOS file from another laptop to rewrite (), but clear ME is needed.
            Can someone help me?
            Files:
            11-10-2023, 11:50 AM
