Dell 7540 8fc8 password
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: °
    Originally posted by mediadoctor
    I'm use CH341a with flash verify. But after flashing the notebook restart always after ~20 seconds and screen stay black
    Try and be careful with the things mentioned in my previous post.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • mediadoctor
      • Oct 2020
      • 34
      • UA
      Re: °
      Thank you Vesko356, but the same after flashing
      I flash my dump and this work, but bios locked
      Have you unlocked bios from another dell 7540?
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Re: °
        The unlocked bios is OK. As I said, you are obviously making a mistake somewhere, in my opinion it is most likely in the programming process of the chip, that is why I said to do a proper verification, the ch341a is well known for the problems it creates, and this is especially true for large chips like the 32mb.
        In addition, it is good to wait a little longer at the first boot after programming the chip with the unlocked bios, because the first start in this case is much longer than usual.
        • mediadoctor
          • Oct 2020
          • 34
          • UA
          Re: °
          Wait time after flashing about 15 min., but many restarts and black screen
          Have you another unlocked bios for 7540?
          • mediadoctor
            • Oct 2020
            • 34
            • UA
            Re: Dell 7540 8fc8
            Originally posted by drefo
            Hello here is the bin file that worked for me, thanks again
            This file work! But very long start bios.
            Can you change it?
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #26
              Re: Dell 7540 8fc8 password
              Things don't work that way, you can't take a dump from someone else's machine and put it on yours just like that and expect everything to be fine.
              I'm sorry but since you didn't even bother to explain, did you try again to do everything I told you in a way I told you it should be done, I have no intention of helping you any further.
              • Markus1741
                • Sep 2020
                • 950
                • N/A
                #27
                Re: Dell 7540 8fc8
                Can you change it?
                Hello, The BIOS you used hasn't cleaned the ME region, that can't work.
                I don't want to upset Vesko356 either, since he tried to help you.
                But you should already use an ME region cleaned BIOS, otherwise it won't work.
                Good luck with the ME Cleaned Version of
                https://www.badcaps.net/forum/showpo...9&postcount=12
                • mediadoctor
                  • Oct 2020
                  • 34
                  • UA
                  #28
                  Re: Dell 7540 8fc8
                  [QUOTE=Markus1741;1211921]Hello, The BIOS you used hasn't cleaned the ME region, that can't work.
                  Thank you all!
                  Markus1741 you are the best, your version work correct!
                  • DBSDBS
                    #29
                    I have locked Precision 7540 with password FKS3P13-8FC8
                    Can someone help me?
                    • aldopc
                      • Jul 2017
                      • 477
                      • Chilito
                      #30
                      Hello you must read your chip bios and upload the bin.
                      • josebml
                        • Nov 2015
                        • 41
                        • spain
                        #31
                        I have Dell 7540 with password bios, can you remove please?
                          • 21968
                          Please read the rules before posting,you must post the service tag !
                          • josebml
                            • Nov 2015
                            • 41
                            • spain
                            #33
                            Sorry,
                            My service tag is: 102R453
                            • gstronger
                              • Mar 2020
                              #34
                              Hello can you help me please, I have a Dell 7540 with password Service Tag: 3XP4Q13-8FC8 thank you.
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                #35
                                here
                                • gstronger
                                  • Mar 2020
                                  #36
                                  Originally posted by volinakis
                                  here
                                  Hi, thank you! it's working, but I have a problem with programming the service tag. It is not saving.
                                  I tried to setup and save, and after reboot still had the same empty space.
                                  Can you help me please how to resolve this issue? Thank you.
                                  • volinakis
                                    • Jan 2021
                                    • 2874
                                    • N/A
                                    #37
                                    try this clean ME version.
                                    • Markus1741
                                      • Sep 2020
                                      • 950
                                      • N/A
                                      #38
                                      Hello you can also try this file once ...
                                      • hollo13
                                        • Mar 2017
                                        • 21
                                        • Hungary
                                        #39
                                        Hello everyone! Please I need to unlock DELL Precision 7540 BIOS, here is the dump! Thanks a lot!
                                        ST: 52R8633
                                        • Markus1741
                                          • Sep 2020
                                          • 950
                                          • N/A
                                          #40
                                          ST: 52R8633
                                          Try ...
                                            Dell 8FC8 Bios Password Patcher
                                            by SMDFlea
                                              DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                              The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                              your own machine,you forgot the password you set a long time ago or you mistyped the password
                                              when setting it and cannot get in again.
                                              DISCLAIMER: THE SCRIPTS
                                            11-03-2023, 06:02 AM
                                          • overclocker1786
                                            [Bios Password Unlock Request] [Dell OPTIPLEX SFF PLUS 7020] [8FC8 method]
                                            by overclocker1786
                                            Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
                                            Thanks.
                                            1hj4z24 = Service tag
                                            A schematic would also be amazing if anyone has one!...
                                            08-31-2024, 08:46 PM
                                          • Lubazi
                                            DELL Precision 7540 Bios password
                                            by Lubazi
                                            SERVICE TAG: 270Q3Z2
                                            MAINBOARD: EDA50 LA-H271P Rev: 1.0
                                            Hello, my BIOS has a password, I need a BIOS that unlocks my password.
                                            I only have WINBOND 25Q80DVSIG1939 on the board
                                            Found as a BIOS chip, a 1 MB file is stored there. I uploaded this file here. If I'm wrong and another chip is the BIOS chip, please let me know.
                                            I am grateful for any help....
                                            10-03-2024, 03:58 AM
                                          • x44n
                                            Dell Latitude 7330 password 8FC8
                                            by x44n
                                            my dell is stuck on the Dell Security Manager
                                            Can someone please delete this password from bios?
                                            Thank you a lot....
                                            01-21-2024, 02:35 PM
                                          • skinner
                                            Dell Latitude 9510 Bios Password With 8FC8 Suffix
                                            by skinner
                                            Looking for some help with a bios password. Any help would be appreciated.
                                            Dell Latitude 9410
                                            Service Tag - H803043
                                            Board - LA-J541P REV 1.0...
                                            05-17-2024, 04:02 PM
