HP Pavilion - 14-ce0505sa i7 8 Gen Bios needed
  • mnciks11
    • Aug 2019
    • 347
    • south Africa
    Hello guys
    I have HP Pavilion - 14-ce0505sa
    hp model : G7A-2G DA0G7AMB6D0 REV : D
    Processor : i7 8 Gen CPU
    Turns on , nothing on the screen , Caps flashes 3 times and 2 fast flashes…
    When I checked online for this error , it related to embedded controller being timed out of which I believe it's bios issue
    Below I haves attached my old backup file for this laptop anyone please assist
  • peste
    • 13924
    • ROMANIA
    Re: HP Pavilion - 14-ce0505sa i7 8 Gen Bios needed
    Originally posted by mnciks11
    Hello guys
    bios extracted from the HP site update, the laptop has two bios variants, yours is 084B9 ...
    DMI-220000 - 220106F
    KEYWIN 228000 - 22803F
    • mnciks11
      • Aug 2019
      • 347
      • south Africa
      You are the best brother it's not working 100% , I went online as well , hp support, I got exe file where extracted the bin files, but they were little bit bigger , how do you edit them , I need guidance so that next time I won't bother you and be able to assist others on the forum
        • 22279
        Most of the newer hp updates will decrypt the bios to the right size,if you run the exe,it gives 3 options,choose save to a location.For some others you can decrypt using hewprsa ,google it.
        With an Insyde bios the DMI is usually in one big block, the win key can be in the same block or in a different place.If you flash a virgin bios you will lose the DMI ,its easier to learn how to copy the DMI over,it saves having to use nbdmifit ,HP BCU and its much quicker .Open your backup and the virgin bios with a hex editor and compare them (look at the off-sets given by @peste), you can find the dmi by searching for the model number,or by other keywords such as notebook
        • TECHO TN
          • Jan 2024
          • 72
          • algeria
          thank you sir
          i have the same problem i will try to flash it with the first one REV D
          i hope it will work
