Need toshiba dablgdmb8d0 rev d bios
  • bilen
    • Aug 2014
    • 632
    • istanbul
    Part number : Psk6re
  • bilen
    • Aug 2014
    • 632
    • istanbul
    Re: Need toshiba dablgdmb8d0 rev d bios
    help? nobody?
      • 20304
      help? nobody?
      Backups ?
      • Repdata
        • May 2020
        • 67
        • Deutschland
        testen
        • zenny95
          • Aug 2017
          • 28
          • romania
          Try
          • lrservicios
            • May 2016
            • 127
            • españa
            Originally posted by zenny95
            Try
            Thank you this is Working For DABLGDMB8D0 REV : D bios
            • Quemasda24
              • 7
              • Spain
              Also working on a TOSHIBA Psk6re with motherboard DABLGDMB8D0 REV D. I have loaded both EC and main BIOS. The system turns on, all voltages working but no image and the system turns off. Any other possible bios files for this MB?
              Regards!​
            • Quemasda24
              • 7
              • Spain
              These are the actual bios (back.rar). It turns on, activates all the power supplies, cpu and gpu got warm but no image and turns off. When received it was manipulated and got some bios (Original BIOS.rar) with which cycled over 3 times turning on and off. Its serial is 4B239018W.
              • Quemasda24
                • 7
                • Spain
                I reprocessed zenny95's files for the main with clean ME. No change, basically same response. It seems like if part of bios is correct but not the rest, got stuck and turns off. Any hint?
                Regards!
                • Quemasda24
                  • 7
                  • Spain
                  help? nobody?
                  • kalilinux25
                    • Mar 2018
                    • 2069
                    • ZAMBOANGA SIBUGAY
                    Originally posted by Quemasda24
                    help? nobody?
                    I think your two zip files of bin is not same of your serial number 4B239018W
                    because the back.rar its a TOSHIBA SATELLITE L750 PSK6ME-02E004EN SN:4C100446W
                    and the Original BIOS.rar is TOSHIBA SATELLITE L750D PSK4UE-00V010RU SN: 7B515843W
                    What is the motherboard code ? DA0BLBMB6F0 REV F0?
                    • Quemasda24
                      • 7
                      • Spain
                      Thnak u for the feedback! The MB is a DABLGDMB8D0 REV D, the laptop model is psk6re-01300yce from TOSHIBA. Based in th thread it seems Zenny95's bin files worked for this motherboard. Any hint how could I get the righ bios for this unit?
                      • kalilinux25
                        • Mar 2018
                        • 2069
                        • ZAMBOANGA SIBUGAY
                        that will be ok if the unit is functioning now
                        • Quemasda24
                          • 7
                          • Spain
                          Sadly it turns off after a few seconds into boot. All the voltage reels seem ok but no VCC to the LCD. Starting to think it might have an issue with the GPU. Thank you for your comments.
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • lambungay2023
                            TOSHIBA C55-B868 BIOS part. no.PSKT4V
                            by lambungay2023
                            hi please help need bios file for my TOSHIBA C55-B868 BIOS part. no.PSKT4V-03U001AR ..HERE IS ATTACHED BIOS STOCK....
                            04-28-2023, 09:31 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • Bloodhoundje
                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                            by Bloodhoundje
                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                            I have desoldered the bios chip (GigaDevice...
                            03-16-2024, 03:12 PM
