Part number : Psk6re
Need toshiba dablgdmb8d0 rev d bios
Re: Need toshiba dablgdmb8d0 rev d bios
testenAttached Filesif you find these attachements useful please consider making a small donation to the site
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
Also working on a TOSHIBA Psk6re with motherboard DABLGDMB8D0 REV D. I have loaded both EC and main BIOS. The system turns on, all voltages working but no image and the system turns off. Any other possible bios files for this MB?
Regards!Comment
These are the actual bios (back.rar). It turns on, activates all the power supplies, cpu and gpu got warm but no image and turns off. When received it was manipulated and got some bios (Original BIOS.rar) with which cycled over 3 times turning on and off. Its serial is 4B239018W.Attached Filesif you find these attachements useful please consider making a small donation to the site
I reprocessed zenny95's files for the main with clean ME. No change, basically same response. It seems like if part of bios is correct but not the rest, got stuck and turns off. Any hint?
Regards!Comment
I think your two zip files of bin is not same of your serial number 4B239018W
because the back.rar its a TOSHIBA SATELLITE L750 PSK6ME-02E004EN SN:4C100446W
and the Original BIOS.rar is TOSHIBA SATELLITE L750D PSK4UE-00V010RU SN: 7B515843W
What is the motherboard code ? DA0BLBMB6F0 REV F0?Comment
Thnak u for the feedback! The MB is a DABLGDMB8D0 REV D, the laptop model is psk6re-01300yce from TOSHIBA. Based in th thread it seems Zenny95's bin files worked for this motherboard. Any hint how could I get the righ bios for this unit?Comment
that will be ok if the unit is functioning now
Sadly it turns off after a few seconds into boot. All the voltage reels seem ok but no VCC to the LCD. Starting to think it might have an issue with the GPU. Thank you for your comments.Comment
by piratiHello everyone,
Channel: BIOS Requests ONLY!
hi please help need bios file for my TOSHIBA C55-B868 BIOS part. no.PSKT4V-03U001AR ..HERE IS ATTACHED BIOS STOCK....
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
