Huawei BoB-WAH9 bios dump
  • Jaime78
    • Jul 2015
    • 8
    • Andorra
    Hi all members and happy new year, i need a Huawei BoB-WAH9 bios and
    the motherboard is:
    DAH98MMB8D0 REV: D HF
    MODEL H98M
    I attacched two files, the bios dump of my laptop and the original last bios from Huawei web page. The laptop not power on, 3.3v is on power button, 9.8v in battery conection and 0.2v in bios pin. No experience repairing laptops but may be that the bios is corrupt. Can anybody help me? Somebody that verify my dump and compare with the original bios, please.
    Thanks in advance
    • 20674
    Re: Huawei BoB-WAH9 bios dump
    Thanks in advance
    Try this one.
    • Jaime78
      • Jul 2015
      • 8
      • Andorra
      Good morning, thank you so much, I will test it and tell you the result. Have a nice day
      • Jaime78
        • Jul 2015
        • 8
        • Andorra
        Same problem sir!! May be the problem is in other place of the motherboard, thanks.
        • Keep3r88
          • Mar 2017
          • RF
          Originally posted by SMDFlea
          Try this one.
          not work bios
          • Lex-
            • May 2011
            • 18
            ... The laptop not power on, 3.3v is on power button, 9.8v in battery conection and 0.2v in bios pin...
            Hi Jaime78, please let us know if you repaired the Huawei BoB-WAH9 ?
            Thanks.
            • Jaime78
              • Jul 2015
              • 8
              • Andorra
              Hi, no, I haven't repaired the motherboard. Only tested bios THAT SMDFlea sent to me. Sorry
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
