AMITSESetup Decryptor
  • TraJikar Mac
    • Jun 2025
    • 28
    • Turkey
    #221
    Originally posted by Stefan Steff
    This is your rebuilded bios.
    Provide feedback .
    Update:
    I flashed the copy you sent into the BIOS chip successfully, and turned on the PC, but still the same, it only turns on but only black screen, and then it turns off automatically.
    I also tried to use the flashing via the USB (G712LWS.CAP & G712LWS.BIN) while click and hold on (Ctrl + Home) or (Fn + Esc) but it kept turning off automatically.
    Additional information:
    - Led lights and keyboard turn on but then they turn off again as soon as the laptop turns off.
    Update for previous posts:
    I was able to install the copy back into the other chip without errors (after i bought 1.8v adapter to the CH341A flasher).
    • TraJikar Mac
      • Jun 2025
      • 28
      • Turkey
      #222
      Originally posted by TraJikar Mac
      Update:
      Any help please?
      • Stefan Steff
        • Mar 2024
        • 227
        #223
        Any help please?
        The attached BIOS file is working on another laptop like yours.
        I transferred the DMI info from your dump so it should work with your laptop too.
        Has the 314 version BIOS and a clean ME Region...
        Good Luck!
        • TraJikar Mac
          • Jun 2025
          • 28
          • Turkey
          #224
          Good Luck!
          Broooo, broo, thank you so much!!
          You don't know how much happy I am!!!
          IT WORKED!!
          Man thank you so much!
          BTW, I'm still a student that takes his monthly income from my family, though, I'll cut from my earnings this month and donate to you or the website, IDK actually for who to donate.
          But thank you again, thank you so much. 🌹🌹
          EDIT:
          1: It turned on normally.
          2: It opened the BIOS.
          3: THERE IS NO BIOS PASSWORD. (thank you till the end of your life and who ever gave you this experience and who ever runs this website).
          4: It opened/booted to Windows normally.
          • TraJikar Mac
            • Jun 2025
            • 28
            • Turkey
            #225
            Good Luck!
            The laptop worked, but it couldn't detect the Nvidia graphics card, would that be because of the other chip that I erased at the beginning? Even though i reinstalled the same backup image into it later?
            Or what could be the problem, do you have any idea bro?
            • TraJikar Mac
              • Jun 2025
              • 28
              • Turkey
              #226
              Good Luck!
              Hey bro, could you modify G712LWS file? I mean the same way as you did to the latest file.
              I found that G712LW (Without S) posts driver for RTX2060, while mine 2070S, which caused the windows not to detect the correct GPU I have.
              Thanks in advance.
              • Stefan Steff
                • Mar 2024
                • 227
                #227
                Thanks in advance.
                Now you can program your BIOS , wonderful...
                Try this file first : backupasusrog_test1_NVidia as thisis your original fixed
                Try this second : nonvidia as this is the last BIOS with wich started but NVidia not recognised.
                • TraJikar Mac
                  • Jun 2025
                  • 28
                  • Turkey
                  #228
                  Thank you for helping me bro, I tested the first file (test1_Nvidia) and after i turned on the laptop, it booted to the BIOS and to windows, but didn't display anything at all, the screen was turned off completely (shutdown or no electricity).
                  So I didn't test the other file, but went back to to test an earlier file you uploaded (POST #219): New_BIOS.zip and downloaded it again and flashed it, it worked and everything was fine, even the GPU, just perfect.
                  And to make sure that everything is okay, I booted the BIOS and installed the manufacturer file (I didn't rename it, just kept it as it is after I downloaded it from ASUS website and extracted it), and then copied it to a USB flash memory, and flashed the image via the BIOS itself ==> F9 ==> F10 ==> Ok/Enter.... It then restarted for 2 times and then turned on normally and everything is perfect now.
                  I also want to say that I apologize about something happened earlier, which is when I tried to flash the same file and then the PC refused to turn on, that was because I didn't assemble the heatsink to the motherboard due to the amount of thermal paste I had (thermal grizzly (Thermal Grizzly Kryonaut Extreme 2GR) so I thought the pc would at least boot to the bios or something before it turns off again, I was wrong, I admit it... And this because of the lack of experience I have.
                  So in short:
                  - Flashed New_BIOS.zip (8.89 MB) again.
                  - Assembled all laptop's components together, including the heatsink.
                  - Turned the pc => booted to Windows => Restarted and booted to Windows many times. To make sure everything is okay).
                  - Downloaded G712LWSAS314 => The extracted file: G712LWS-AS.314.
                  - Copied it into USB flash memory => booted to BIOS => installed the file with the same name (G712LWS-AS.314).
                  - Booted to Windows, restarted many times, checked all drivers.
                  Result:
                  IT IS 100% WORKING + No Errors At All + No BIOS Admin Password.
                  Thanks for all your efforts, I'll tomorrow transfer some money to a crypto wallet and donate to you.
                  Also, when the first time I posted and mentioned that (I just donated...etc) that was because I really donated (a few dollars only, this what I'm capable of) and because I wanted to give it as an advance thanks. And also because that I saw under each other post a request for donation.
                  • Stefan Steff
                    • Mar 2024
                    • 227
                    #229
                    So in short:
                    Result:
                    I'm glad you sorted out and you're very welcome.
                    • shadowgesit
                      • Jul 2025
                      • United Arab Emirates
                      #230
                      Thanks a lot. It's working on my Asus ROG G513RW. I read and dump my bios using the Aptio V from https://www.ami.com/bios-uefi-utilities/. And run this python to decode the pwd. Boom!
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                        HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-06-2024, 10:56 AM
                        HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                        HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
