Thanks you so much! and sorry for english (translate), Saved this computer from trash !!!!
AMITSESetup Decryptor
Tried this but didn't succeed to find password, any ideas?
Machine is Asus GL10CS-NR113T
SN: K7PDCG001024270Attached FilesPremium supporters get full download access and other benefits.
SN: K7PDCG001024270[Attached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Please I ned help to decrypt password or else just to unlock. thank you
Panasonic / Toughbook CF-195MAC3CA
SN:4KKSA05211
Motherboad: DFU2123ZB
Panasonic / Toughbook CF-195MAC3CAAttached FilesPremium supporters get full download access and other benefits.
Hi, can someone help unlock this file, I tried zeroing out the password in 2 locations but it didn't seem to work - just black screen, what am I missing?
Toughbook CF-20GV-52TE
Serial 2EKCD30382
Don't worry, I fixed it - one of the tiny resistors had broken.
Now the BIOS is unlocked the HDD doesn't seem to work anymore, aaarghComment
Sorry for late reply ..!
With my trial and error, I manage to get it worked. and just comparing the bin file I got the same result as you do
so from this I have learned something new
And thanks for your response knowing i'm in the right pathsComment
Hi, I have an Asus E510MA with an administrator password in the BIOS that I don't know and I can't find a way to delete it. The Alt+R method doesn't work, the Decryptor doesn't find anything and with the Freeware Hex Editor software the probable password is not decoded from the site https://www.rapidtables.com. I also managed to update the BIOS but the password remained. What should I do? ThanksComment
The serial number is:
MANOCX27H786434
Try and Update.Attached FilesPremium supporters get full download access and other benefits.
Is it not possible to decrypt the password from the bios backup I sent you? If via software it tells me that the bios you corrected is not valid, what happens if I flash it forcibly with a programmer? And in any case, since I had updated the bios to the latest version but the password remained, could it be that this is saved on another chip?Comment
I can't decrypt your password but I can remove it if it's ok...Is it not possible to decrypt the password from the bios backup I sent you? If via software it tells me that the bios you corrected is not valid, what happens if I flash it forcibly with a programmer? And in any case, since I had updated the bios to the latest version but the password remained, could it be that this is saved on another chip?Attached FilesPremium supporters get full download access and other benefits.
Buy an SPI programmer.Comment
by raydemHello,
I have a Sony KD-75XG8096 that has backlight and sound, but no picture.
I went straight to the T-CON board (18Y_SNTH2TA6AV0.1) and checked the following:
VIN = 12 V
Fuse is OK
1.5 V, 1.8 V, 2.5 V, and 3.3 V rails are present and correct
There are no VSS1, HAVDD, AVDD1, or HVIN_12 voltages
I have not found any short circuits. I also used rosin to help detect any possible hotspots, but nothing was found.
The HVIN_12 voltage is controlled by a MOSFET through an RT6948. The MOSFET tests good, and the RT6948 output to... -
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by jheunnei have a nitro acer laptop motherboard gh53z la-l031p rev1b no image but has blue light on screen when turning on. try external screen and new screen still got no image. as for checking the laptop caps key light is functioning normally when press even when keyboard lights turn off when press it lights up. I do flash its bios same problem. its like the laptop boots with no image only blue light on screen no image. is there any solution for this one or need repair for the gpu. allso i would like to know how to extract exact bin file on support bios of acer coz it shows bigger size from its orignal....
This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 10:56 AM
- Loading...
