DAZ8VMB18D0 REV D Bios Bin Latest
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi I have a board that if power pressed automaticaly turns off Hope somoene can recreate a good bios bin file
    BOARD : DAZ8VMB18D0 REV D
    LAPTOP: E5-475G-50ST
    SNID: 64108336176
    2016-10-14
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Re: DAZ8VMB18D0 REV D Bios Bin Latest
    try this two dumps
    • alihomee
      • Dec 2012
      • 1596
      • malaysia
      Try this file tested
      • than_22
        • Sep 2017
        • 53
        • philippines
        can someone clear ME my backup
        DAZ8VMB18D0 REV
        • than_22
          • Sep 2017
          • 53
          • philippines
          this is for the other one,, screen is on but no picture
          • anshad
            • Nov 2010
            • 249
            DAZ8VMB18D0 REV
            Your backup file, Me Cleaned. if only ME is causing issues, this should work.
            • nopek
              nopek commented
              Editing a comment
              this bios is work
          • than_22
            • Sep 2017
            • 53
            • philippines
            i will try this thank you
            • than_22
              • Sep 2017
              • 53
              • philippines
              it works thank you
              • anshad
                • Nov 2010
                • 249
                Try this. BIOS extracted from Acer official update file with your Windows Key inserted. If BIOS is the cause of no display, this should solve the problem. Otherwise verify voltages and signals.
                • smallvhin
                  • Jul 2015
                  • 192
                  • philippines
                  Master help me to fix my Bios file. more thanks
                  • lapfix
                    • Mar 2020
                    • 2765
                    • my workshop
                    Try and give feedback
                    New bios + dmi+win key+clean me
                    • smallvhin
                      • Jul 2015
                      • 192
                      • philippines
                      more thanks master it's working
                      • Joztu
                        • May 2022
                        • 46
                        • Nigeria
                        Hello, please i need bios for this laptop
                        acer ES1-431
                        Board number: DAZ8ADMB6D0 REV: d
                        S/N: NXMZDEM0196170E42D7600
                        SNID: 61705841376
                        laptop doesn't boot up, fan spins very fast with no display
                      • rafniox0059
                        • Dec 2021
                        • 3
                        • Philippines
                        Hello! Can someone please help me. My laptop powering on but no display.
                        Here's the info:
                        DAZ8VMB18D0
                        MODEL:Z8V X32
                        S/N: NXGJWSP002636126217600
                        SNID: 63607529776
                        • rafniox0059
                          • Dec 2021
                          • 3
                          • Philippines
                          BRO, CAN YOU SEND MO BIOS BIN?WERE USING THE SAME UNIT.
                          • lbslakmal
                            • 49
                            • sri lanka
                            This bin working. Thank you
                            • arreii
                              • Nov 2025
                              • Philippines
                              can you help me my aspire e5 475 no display and it turn off
                              • peste
                                • Dec 2016
                                • 13759
                                • ROMANIA
                                post S/N, full name and model, motherboard model, ,etc.
                                post the contents of the bios chip even if it is corrupted..
                                The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                solder wires between the programmer and the bios chip..
                                you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • cr4zychriss
                                  by cr4zychriss
                                  • Rebrand: PC Specialist
                                  11-14-2025, 04:04 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
