da0g7hmb8g0 rev g read ok
da0g7hmb8g0 rev g bios
There is an error reading the document, need someone to rescue it, try another document and it won't recognize the SSDAttached FilesComment
Hello Everyone Neeed Help !
I Have HP 15-EG0053CL
Serial Number # 5CD122J5MC
Part Number # DA0G7HMB8G0
Bios With Display issue....With abbassink's file Display comes after 15 seconds but its NVME not Detected with this file i've changed NVME but thats too not detected ANY NVME NOT DETECTED but M2 SSD shows in Bios Setup .....it's NVME is ok i've checked it on externally it shows data also.....
Kindly anyone please Make my file to work.... i've attached original file...Attached FilesComment
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Pavilion 15-eg1001TU
SN: 5CD145B9FM
M/B Part no. DA0G7HMB8G0 REV G
BID 0898AAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Hi guys PLZ needed bios file
hp pavilion 15 EG0007NK da0g7hmb8g0 rev g
- Prod id : 2Q9H0EA#BDH
- SN# 6CD043RHLK
BID : 20WW2SAT602#SBH4#DBH4
- SN# 6CD043RHLK
Hello pls repair my bios no detect nvme
da0g7hmb8g0 rev g 15-eg0052nw (381F4EA)
You must post the serial number/service tag or SNID with every bios request.Please read the rules https://www.badcaps.net/forum/troubl...before-posting
HP Pavilion Laptop 15-eg0052nw (381F4EA)Attached Files
hi HP Pavilion Laptop 14-dv0598na (2S3C7EA)
sn 5cd20252cq
id 2s3c7ea
no display
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM - Loading...
