need Bios Asus X542Bp last update
  • beshow
    • Nov 2016
    • syria
    As308
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Re: need Bios Asus X542Bp last update
    try this dump
    • beshow
      • Nov 2016
      • syria
      thanks
      it is working
      As308
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Anchar777
        ASUS P1412CE need BIOS DUMP
        by Anchar777
        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
        06-26-2025, 03:39 AM
