HP DV6-7000ee bios fix
  • biber
    • Feb 2015
    • 104
    • macedonia
    hi, I need bios fix pls. the laptop is in loop mode, turns off and on, no image. Laptop is turning on with other bios but is missing: Product name, Configuration, Serial Number, Board CT number, and cant see SSD.
  • peste
    • Dec 2016
    • 12792
    • ROMANIA
    Re: HP DV6-7000ee bios fix
    try..
    • biber
      • Feb 2015
      • 104
      • macedonia
      Originally posted by peste
      try..
      Same, boot loop :/
        • 20888
        Same, boot loop :/
        Your BID is 01818 . See this thread,post #40 https://www.badcaps.net/forum/showthread.php?p=1065799 .Use the virgin bios at post #24,copy your DMI from your backup to the new bios using the offsets in the picture at post #40 .If it doesn`t boot with that bios the problem is somewhere else.
        • biber
          • Feb 2015
          • 104
          • macedonia
          i ve tried this bios and is working but with the above mentioned problems
            • 20888
            see post #4.
            • biber
              • Feb 2015
              • 104
              • macedonia
              Originally posted by SMDFlea
              see post #4.
              idea is to insert the Product name, Configuration, Serial Number, Board CT number from my motherboard to new bios that can't recognize this data? as I can see this lines from 3A0000 to 3A2FFF in working bios are empty. trying now
              • biber
                • Feb 2015
                • 104
                • macedonia
                bios is ok now, it can see SSD, bootable USB stick but won't boot from anything. only black screen and blinking line in the left corner. i also have tried HDD self-check F2 utility and is working, but won't boot from any bootable device :/ Also, F9 boot menu can see bootable devices but wont boot from any
                what can cause this ?
                • biber
                  • Feb 2015
                  • 104
                  • macedonia
                  it wont boot from gpt partition. from mbr is ok, in bios now there is no efi boot, I suppose this bin file is from an older laptop that doesn't have efi boot.
                  Maybe someone has HP DV6-7000 Series Goya_Balen 1.0 - DDR3
                  11254-2
                  48.4ST04.021
                  BIOS?
                  • biber
                    • Feb 2015
                    • 104
                    • macedonia
                    maybe someone will need bin for this mobo.
                    • ganjybas
                      • Mar 2024
                      • Moldova
                      Здравствуйте, скажите этот биус подойдёт для ноутбука HP dv6t 7000?
                      Hello, tell me, is this Bius suitable for the HP dv6t 7000 laptop?
                      in English please..
                      • peste
                        • Dec 2016
                        • 12792
                        • ROMANIA
                        in English please..
                        post S/N, full name and model, motherboard model, product number,post the contents of the bios chip even if it is corrupted..etc.
