hi, I need bios fix pls. the laptop is in loop mode, turns off and on, no image. Laptop is turning on with other bios but is missing: Product name, Configuration, Serial Number, Board CT number, and cant see SSD.
HP DV6-7000ee bios fix
Re: HP DV6-7000ee bios fix
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs. -
Your BID is 01818 . See this thread,post #40 https://www.badcaps.net/forum/showthread.php?p=1065799 .Use the virgin bios at post #24,copy your DMI from your backup to the new bios using the offsets in the picture at post #40 .If it doesn`t boot with that bios the problem is somewhere else.Comment
i ve tried this bios and is working but with the above mentioned problemsAttached Filesif you find these attachements useful please consider making a small donation to the site
bios is ok now, it can see SSD, bootable USB stick but won't boot from anything. only black screen and blinking line in the left corner. i also have tried HDD self-check F2 utility and is working, but won't boot from any bootable device :/ Also, F9 boot menu can see bootable devices but wont boot from anyYour BID is 01818 . See this thread,post #40 https://www.badcaps.net/forum/showthread.php?p=1065799 .Use the virgin bios at post #24,copy your DMI from your backup to the new bios using the offsets in the picture at post #40 .If it doesn`t boot with that bios the problem is somewhere else.
what can cause this ?Last edited by biber; 11-21-2021, 09:56 AM.Comment
it wont boot from gpt partition. from mbr is ok, in bios now there is no efi boot, I suppose this bin file is from an older laptop that doesn't have efi boot.
Maybe someone has HP DV6-7000 Series Goya_Balen 1.0 - DDR3
11254-2
48.4ST04.021
BIOS?Comment
maybe someone will need bin for this mobo.Attached Filesif you find these attachements useful please consider making a small donation to the site
post S/N, full name and model, motherboard model, product number,post the contents of the bios chip even if it is corrupted..etc.
Every donation made will go towards server fees and maintenance costs.Comment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
Channel: BIOS Requests ONLY!
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by evilgenius31Hi All,
I was told to post my corrupted bios dump here. My Zephyrus G14 GA401QH-211 is missing the serial number in the bios. NVME drives can't be detected by the bios either. The bios version is 410.
Serial: M4NRKD01530915H
Thanks in advance!...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
