Medion MD 98760
  • didouche1200
    • Oct 2016
    • 357
    • 82679911441
    Medion MD 98760
    md 98760 10310-1 m51p1 mb 10310-1 dump bios pls
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    Re: Medion MD 98760
    Hi bro .this is Bios dump.
    • didouche1200
      • Oct 2016
      • 357
      • 82679911441
      Re: Medion MD 98760
      think
      • didouche1200
        • Oct 2016
        • 357
        • 82679911441
        Re: Medion MD 98760
        no display with this dump
          • 20848
          Re: Medion MD 98760
          post the original bios backup
          • didouche1200
            • Oct 2016
            • 357
            • 82679911441
            Re: Medion MD 98760
            original bios
            • didouche1200
              • Oct 2016
              • 357
              • 82679911441
              Re: Medion MD 98760
              i put the original bios is it new thank you
                • 20848
                Re: Medion MD 98760
                original bios
                try this.
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • MDSI
                  HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                  by MDSI
                  I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                  Details:
                  Model : HP OMEN 17-an012nf
                  Motherboard Part Number : DAG3BAMBAF0 REV : F
                  Serial Number (S/N) : 5CD7280D51
                  BIOS chip : Winbond W25Q64VSIQ
                  Programmer : EZP2023+
                  Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                  I already...
                  07-28-2025, 07:11 AM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
                • DynaxSC
                  Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                  by DynaxSC
                  I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                  It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                  I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                  11-06-2022, 05:22 PM
