Looking for BIOS dump Quanta X31 DAX31MB1AA0 REV: A Model 13-ac023dx s/n 5CD72062NJ
  • mehio
    • Oct 2018
    • turkey
    hello i need bios dump for HP dax31mb1aa0 rev a
    please
    • 22293
    Re: dax31mb1aa0 Bios dump
    what is your bios BID number ? .Post your bios backup if you don`t know.
    • denilloo
      • May 2013
      • 60
      • indonesia
      extract from working laptop
      • njsmersh
        • Nov 2021
        • 4
        Looking for BIOS dump Quanta X31 DAX31MB1AA0 REV: A Model 13-ac023dx s/n 5CD72062NJ.
        Thanks!
        NJ
          • 22293
          Re: Looking for BIOS dump Quanta X31 DAX31MB1AA0 REV: A Model 13-ac023dx s/n 5CD7206
          Thanks!
          NJ
          post your backup
          • Siddig
            • Jun 2017
            • 264
            • Sudan
            Thanks!
            NJ
            This is Bios+Ec dump
            • njsmersh
              • Nov 2021
              • 4
              Thanks a lot!
              Actually I have found the right dump at the HP web site.
              Now I need to fix several parameters as model id etc, I'm using HP bios config tool which works fine. But I could not find UUID and System Board CT number.
              It should be possible to extract these values from the original dump I'm attaching here.
              Regards!
              • Siddig
                • Jun 2017
                • 264
                • Sudan
                Thanks a lot!
                Regards!
                please backup your old bios dump to build for you.
                • njsmersh
                  • Nov 2021
                  • 4
                  Please check the post above. "original.zip" is the backup of the corrupted bios.
                  regards
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
