Help please HP Zbook 15 G3
  • paulyboy
    • Mar 2020
    • 130
    • New Zealand
    I was trying to remove a bios password, I removed these chips and read the data from them and unlocked them via the awesome tool on the forum but upon soldering them back now my darn laptop wont switch on and the power button flashes and also the charging port is illuminated
    I likely messed something up, am using a tl866 programmer, also could anyone be so kind as to show an image of bios chip orentation for this model incase I made a booboo
    Kind Regards
    Paul
  • peste
    • Dec 2016
    • 13600
    • ROMANIA
    Re: Help please HP Zbook 15 G3
    Kind Regards
    Paul
    use the program only for the 16MB bios ... the other two remain the same ..
    • paulyboy
      • Mar 2020
      • 130
      • New Zealand
      Appreciate that, I've also tried that to no avail, is it possible my reads were bad.
      Would it be ok to flash a bios from the net as I have possibly contaminated the bios.
      Thanks for your time peste
      • paulyboy
        • Mar 2020
        • 130
        • New Zealand
        Is there perhaps a repository for the 3 bios,
          • 21907
          Sometimes the unlocker tool doesn`t work.Are the bios at post #1 the original backups.Post a picture of the bios chips on the board
          • paulyboy
            • Mar 2020
            • 130
            • New Zealand
            hi SMD yes there the original from the device 😊 will add pictures shortly
            • paulyboy
              • Mar 2020
              • 130
              • New Zealand
              Here's the pics
              • paulyboy
                • Mar 2020
                • 130
                • New Zealand
                  • 21907
                  Check UT2 ,the 1st picture, pin 4 of the chip is GND.Test the pins with a multimeter. Looks like its the wrong way around
                  • paulyboy
                    • Mar 2020
                    • 130
                    • New Zealand
                    Orientation was correct , I checks ground with multimeter and was algood. Currently got a power light and charging port light. I think my reads maybe bad can anyone please help. Thanks
                    • paulyboy
                      • Mar 2020
                      • 130
                      • New Zealand
                      No start/image was fine leading up to desoldering and reading of bios. Also very well soldered back
                      • zlr8r
                        Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                        by zlr8r
                        Greetings
                        I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                        Serial Number: 5CG3202C16
                        Product #/SKU: 739P0AV
                        CT Number: PRTUE00WBI30YX
                        Description: HP ZBook Firefly 14 inch G10
                        BuildID: 23WWWGAZ602#SABU#DABU
                        Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                        MAC address not found.
                        • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                        10-28-2025, 01:56 PM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • zlr8r
                        Hp Zbook Firefly 14 G8 - mobo: corvette-605qa321330-mb-a01 - need all bios files checked
                        by zlr8r
                        hey guys,
                        i have been working on for days a Hp Zbook Firefly 14 G8 - mobo: corvette-605qa321330-mb-a01.
                        Doesn't Boot - only thing working is an LED flashing orange on/off, that's it
                        - have tried cleaning the Main bios (ME region) which seems to have gone smoothly enough, and have re-soldered it back onto the board, but then I spotted an almost identical Bios chip near the EC on other side, but I don't know what is needed to be done with that bios ?
                        - i have attached my original Main and EC bios's (they are both 32mb! chips)
                        - i have...
                        10-21-2025, 09:39 AM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
