need bios. ACER N15C1
  • renald21
    • Sep 2020
    • 33
    • Philippines
    HI plss.. help me i need tested bios bin file..
    motherboard no.
    A4WAS LA-C611P rev: 1.0
    this is my backup..
    https://www.mediafire.com/file/kmx39...PORIG.bin/file
    thanks a lot!
  • renald21
    • Sep 2020
    • 33
    • Philippines
    Re: need bios. ACER N15C1
    up.. plssss
    • lotas
      • Jan 2016
      • 4936
      • Russia
      Try from Acer Aspire E 14 K4000-55ZJ A4WAS LA-C611P.
      • renald21
        • Sep 2020
        • 33
        • Philippines
        thanks..
        i try istill no display ..
        up
        up!!
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          Originally posted by renald21
          up.. plssss
          try..
          • renald21
            • Sep 2020
            • 33
            • Philippines
            Originally posted by peste
            try..
            tnx
            i try it now.. but still no display..
            • exerion5000
              • Aug 2014
              • 83
              • Argentina
              Original Bios Extracted from manufacturer
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
              • Danfay
                Acer Aspire 3 A317-51G Request Bios in .bin file
                by Danfay
                Hello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
                Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong . The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file .
                The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
                So I updated to version 1.11, which apparently either went wrong or is not functional.
                Does anyone...
                09-25-2023, 02:57 AM
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
