help me dell 7320-7420 PASS
  • dgs3342
    • May 2017
    • 37
    • Italia
    #61
    Re: help me dell 7320-7420 PASS
    Originally posted by Vesko356
    It's under warranty. Contact Dell Support for assistance with proof of purchase.
    Actually I've managed to modify the bios to clean the lock but I don't know exactly how. Very strange.
    • Ferimonka
      • Nov 2019
      • 40
      #62
      Thank you for the file, Unfortunately while soldering to the board I shifted few components and laptop won't power on anymore even bios and components are soldered back.
      I have got one more laptop with identical motherboard (Dell Latitude 7320). Could you pls unlock the dump file attached for me? I have a private repair shop and learning the stuff. What method you use to clear the pass? Are you able to find it inside the file? You are my saviour with both cleared bioses. Thank you again in advance.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12453
        #63
        Dell Latitude 7320
        • Ferimonka
          • Nov 2019
          • 40
          #64
          Thank you. I programmed the data to the chip and soldered back. Now I can't see any light on and measuring the bios chip pins voltage has changed to 1.8v instead 3.3 Does it needs to be activated somehow or I burned something out again? Thank you for help.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12453
            #65
            What ? How can it change from 3.3 vol to 1.8 vol ? What's code name of chip ? Just to be sure on first boot you have to go into bios settings to disable all security options.
            • Ferimonka
              • Nov 2019
              • 40
              #66
              The voltage changed on the 7420 motherboard as well. It looks like I burned something out but I just soldered the chip with hot gun.I am getting this values on bios chip (Winbond 25R2S6JVEN)
              Pin 1 - 1.3V
              Pin 2 - 1.9V
              Pin 3 - 1.9V
              Pni 4 - 0V
              Pin 5 1.3V
              Pin 6 - 1.9V
              Pni 7 - 0V
              Pin 8 - 0V
              • hoaca388
                Badcaps
                • Jan 2022
                • 12453
                #67
                As far as I know pin number 8 must have 3.3 volts.
                • Ferimonka
                  • Nov 2019
                  • 40
                  #68
                  I found out the voltage is ok when chip is de-soldered. Once soldered back the voltage drops down as mentioned. Any idea why this behavior?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12453
                    #69
                    Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                    • justice171
                      • Feb 2018
                      • 110
                      • South Africa
                      #70
                      Try & leave feedback:
                      Good day, can you assist with the BIOS password for suffix 8FC8
                      Dell Latitude 7420 Board number GDC31 LA-K371P
                      BIOS BIN Below
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12453
                        #71
                        BIOS BIN Below
                        Unlocked
                        • justice171
                          • Feb 2018
                          • 110
                          • South Africa
                          #72
                          Originally posted by hoaca388
                          Unlocked
                          Wow, it worked now I can change settings on the BIOS dude you are a genius I wish I knew how to do it so that I can help others on the badcaps forum.
                          • Kaiser87
                            • Aug 2022
                            • it
                            #73
                            Re: Dell Latitude 7400 Bios Password
                            can you help me? I do not know exactly which chip to read and where to find it.
                            I read this one out but the file is only 1MB. Can this be correct?
                            I have a Latitude 7420 2-in-1 (Not the one in the photo. I got the picture from the internet. But mine looks exactly the same.)
                            • Kaiser87
                              • Aug 2022
                              • it
                              #74
                              It is a winbond 25Q80DVSIG
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12453
                                #75
                                Name of chips ?
                                • Kaiser87
                                  • Aug 2022
                                  • it
                                  #76
                                  Name of chips ?
                                  upper one: winbond 25R256JVEN
                                  lowwer one: XMCC QH128AHIG
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12453
                                    #77
                                    upper one: winbond 25R256JVEN = 32MB Data
                                    lowwer one: XMCC QH128AHIG = 16 MB data.
                                    Read Winbond chip.
                                    • alikhoso0786
                                      • Dec 2021
                                      • Pakistan
                                      #78
                                      Hi to All friend's and expert teacher
                                      need Dell latitude 7420 #9P0R7M-8FC8 bios unlock code...
                                      • imranromi
                                        • Jan 2015
                                        • 1292
                                        • Pakistan
                                        #79
                                        You need to open laptop find bios chip read and post here.
                                        • farouk_1994
                                          • Mar 2021
                                          • 402
                                          • algeria
                                          #80
                                          i have LOCKED bios dell 7420 HELP
