hp elitebook 840 g4 bios bin file request
  • Lover1abd
    • May 2023
    • 14
    After unlock bios unfortunately keyboard Backlit not working why??
    • PRINCECO
      • Jun 2025
      • 12
      • NIGERIA
      #82
      hp 840 bios needed
      old dump bios not working even after trying several bin here
      peste bin didnt work for me
      • alirafee
        • Jun 2015
        • 99
        • iran
        #83
        hi
        Hp Elitebook 840 G4
        6050A2854301-MB-A01
        sn 5CG8196Z5N
        SKU 2FW44UC#
        BIOS DELAY dis
        • Blaze Tech
          Learner
          • 218
          • Ghana
          #84
          Originally posted by alirafee
          hi
          Hp Elitebook 840 G4
          6050A2854301-MB-A01
          sn 5CG8196Z5N
          SKU 2FW44UC#
          BIOS DELAY dis
          TRY
          • alirafee
            • Jun 2015
            • 99
            • iran
            #85
            thanks
            bios not working
            • winbondd
              • Nov 2022
              • Украина
              #86
              Hi , please help me to repair the bios file.
              HP Elitebook 840 G4
              Motherboard 6050a2854301-mb-a01 .
              5CG8060L1J
                • 22415
                HP Elitebook 840 G4
                5CG8060L1J
                Post the 8MB ec_bios as well. Can you explain what the problem is.
                • ronel.dolores@gmail.com
                  • Jul 2025
                  • 8
                  • PHILIPPINES
                  #88
                  I HAVE HP ELITEBOOK 840 G4. IT TURNS ON WITHOUT DISPLAY.AFTER PROGRAMING THE BIOS IT SHOWS PROTECTED BY SURE START AND THEN THE EMBEDDED CONTROLLER MUD DATA DOES NOT MATCH THE BIOS MUD DATA. HOW TO FIX THIS?
                  • LBTT1121
                    • Nov 2024
                    • 1268
                    • Việt Nam
                    #89
                    post motherboard model, Service Tag , etc.
                    post the contents of the bios chip even if it is corrupted..
                      • Jul 2025
                      • 8
                      • PHILIPPINES
                      #90
                      HP ELITEBOOK 840 G4
                      MOTHERBOARD MODEL HP EliteBook 840 G4 6050A2854301-MB-A01
                      SN: 5CG7481LRQ
                      ATTACHED FILES THE OLD BIOS BIN
                      • LBTT1121
                        • Nov 2024
                        • 1268
                        • Việt Nam
                        #91
                        HP ELITEBOOK 840 G4
                        SN: 5CG7481LRQ
                        try https://www.badcaps.net/forum/troubl...67#post1580367
                          • Jul 2025
                          • 8
                          • PHILIPPINES
                          #92
                          I TRIED THESE BUT STILL THE SAME RESULT
                          • buscetta
                            • Oct 2023
                            • 3
                            • Italia
                            #93
                            Hi, I have an HP EliteBook 840 G4
                            S/N: scg81250p0
                            I think the BIOS is corrupted. I'm attaching the original BIOS reading on the card, hoping for your help.
                            Thank you so much.
                            Last edited by SMDFlea; 11-26-2025, 04:52 AM. Reason: translated. translate.google.com
                            • buscetta
                              • Oct 2023
                              • 3
                              • Italia
                              #94
                              S/N: scg81250p0
                              Thank you so much.
                              correzione ID: X3V06AV
                              s/n: 5CG8125DP0
                              main : 6050A2854301-MB-A01
                              • shiyab
                                • Sep 2023
                                • 1749
                                • india
                                #95
                                s/n: 5CG8125DP0
                                hi try
                                • buscetta
                                  • Oct 2023
                                  • 3
                                  • Italia
                                  #96
                                  Originally posted by shiyab
                                  hi try
                                  ciao grazie dell'aiuto ,ma non vanno per me ,connetto l'alimentazione .i led lampeggiano alternativamente giallo/bianco per qualche secondo ,come se stesse facendo un check ,poi si accende tutto e si rispegne tutto ,poi lampeggia bianco/giallo ogni tanto a intermittenza
                                  Hi, thanks for the help, but they don't work for me. I connect the power supply. The LEDs flash alternately yellow/white for a few seconds, as if it were doing a check, then everything turns on and off again, then it flashes white/yellow intermittently every now and then.
                                  in English please..
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • Wutru
                                    HP Elitebook 820 G4 BIOS repair assistance required
                                    by Wutru
                                    Hi guys,
                                    If someone would be able to provide some expertise, I'd be very grateful.
                                    BIOS Corruption - Cause
                                    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                    09-06-2025, 10:32 AM
                                  • lap-top123
                                    Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                    by lap-top123
                                    HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                    Hp Elitebook 850 G8
                                    ProdID 52W98EC#ABD
                                    SN# 5CG1458XQ7
                                    Mac-address #1: 84:14:4D:2C:4B:5B
                                    UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                    Mainboard : 6050A3216701-MB-A01(A1)
                                    08-20-2025, 07:28 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
