HP17-by1033dx bios dump
  • stevespc
    • Nov 2011
    • 18
    • Greece
    I need bios dump for HP17-by1033dx, Thankyou
  • stevespc
    • Nov 2011
    • 18
    • Greece
    Re: HP17-by1033dx bios dump
    my original dump
    • peste
      • 13768
      • ROMANIA
      Originally posted by stevespc
      my original dump
      the bios posted by you has 4MB, it should have 16MB..make a new copy, check it and post again ..
      • stevespc
        • Nov 2011
        • 18
        • Greece
        oh no I reckon it got corrupted, that is all the data on the chip, is there no other plan?
        • peste
          • 13768
          • ROMANIA
          what programmer do you use?
          • stevespc
            • Nov 2011
            • 18
            • Greece
            CH341A with Asprogrammer 2.1
            • peste
              • 13768
              • ROMANIA
              remove the bios chip from the motherboard before reading or writing..if you use the clip you may have errors..if you have nothing to remove the bios chip, glue wires between the programmer and the bios chip, if you do not have an adapter for bios chips stick the chip on the programmer..try this program too ..
              https://www.badcaps.net/forum/showpo...04&postcount=7
              • stevespc
                • Nov 2011
                • 18
                • Greece
                The chip was removed from the board when I dumped it
                • peste
                  • 13768
                  • ROMANIA
                  maybe you have another bios chip on the board?
                  • stevespc
                    • Nov 2011
                    • 18
                    • Greece
                    This is the windbond W25Q128JV, main bios chip
                    • peste
                      • 13768
                      • ROMANIA
                      here is the bios extracted from the HP website update, your laptop has four bios variants, try the 16MB ones in turn..one of them should be ok for your laptop ..
                      • stevespc
                        • Nov 2011
                        • 18
                        • Greece
                        I will try, thank you
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          by haitham sharabati
                          Hello engineers 😀,
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          💀 Problem:😅
                          08-07-2025, 04:54 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
