Dumps dell latitude e5540 working
Dell latitude e5540 bios working
Re: Dell latitude e5540 bios working
With this BIOS wireless card is not detected. I tried other BIOS and it works.Comment
can any one help me
i have this bios bin file and the laptop need 60 second to work and after clear me it dont detected wireless card
the laptop is dell e 5540
Attached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
hello plz ineed clear me this dump to fix my problem is run one time ok turn off then turn on black screen and no work until reset bios
Model Name: latitude e5540
S/N:3qn0q12
Motherboard: vaw50 la-a101p rev1.0 a00 2014-04-11Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi.i need to clear file
i test all file in the forum but somefile delay to display and somefile work very well but fan dont work.
Dell E5540
VAW50 LA-A101P rev 1.0 (A00)
i3-4th
without GPU
sn:5LJNTZ1
Backup file:👇
https://www.badcaps.net/filedata/fetch?id=3748313Comment
i clean me another file .
system work correctly but wifi not work.please repair file..I need this file urgently.
(The file was downloaded from the forum then clean)
Dell E5540
i3-4th
without GPU​Attached Filesif you find these attachements useful please consider making a small donation to the site
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
- Loading...
