HP EliteBook 820 G3 - Reading BIOS
  • Korreia
    • Sep 2021
    • 14
    this is my first attempt atreading the BIOS with the CH341A USB Programmer + SOP8 Test Clip.
    Here is the CMOS Chip I'm pretty sure it is a WINBOND chip. The writing on the chip is unreadable.
    I'm currently having issue that the CH341A Programmer. The run light is not turnning on. only the power light. I've verify that all pin 1 are all well linked and in-line connected..
    To my understanding, this mean that the SOP8 Clip is not well clip. I'm pretty sure it is based on the below picture.
    I'm using the NeoProgrammer 2.2.0.7 located here: NeoProgrammer 2.2.0.7
    I'm also using the driver from here: CH341PAR.EXE
    Again, I'm really not sure what I'm doing wrong. Any help or pointers would be greatly appreciated as I need to extract he BIOS Bin file to clear the password.
    Cheers
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: HP EliteBook 820 G3 - Reading BIOS
    Your BIOS chip seems to be WSON package (https://www.infineon.com/export/site...1129538973.gif) and therefore has no exposed leads on the side where the clip can make electrical contact with.
    From your picture, you have 2 options.
    First: Since you seem to have exposed copper which likely connects to the BIOS chip, you can solder wires to it and match it on your programmer (pin 1 to pin 1, etc)
    Second: You most probably received a small adapter (https://ae01.alicdn.com/kf/H7b90d5fc...P8.jpg_q50.jpg) board together with your programmer. Remove the BIOS chip from the motherboard, solder it on the adapter board and go from there.
    Hope this helps.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      You are trying to use SOIC8 clip with WSON8 chip - not going to happen, unsolder the chip and use WSON8 adapter, or solder wires to the motherboard.
      Become a Badcaps supporter
      Thanks to all supporters.
      • Korreia
        • Sep 2021
        • 14
        Tanks for the reply. It is not socket and I do not want to unsolder it from the board... Again, I'm not sure if it is a WSON8...
        It look like the chip does not have any side leg for the SOIC8 clip to clip onto... Is that possible?
          • 21567
          It is a WSON8 chip (without legs) . The gold pads surrounding it are for a sop8 chip (with legs). The pads are offset and not in a straight line.You can solder wires to the gold pads if you can`t desolder it, as mentioned already,or you could buy a WSON8 pogo pin test probe
          https://www.aliexpress.com/item/1005001830846980.html .There`s 2 different sizes for each of the WSON8 chip sizes, 6X5 and 8X6
          • Korreia
            • Sep 2021
            • 14
            Awesome! I'll try that and psot back
            Cheers
            • Korreia
              • Sep 2021
              • 14
              Hi all, So I got a WSON8 adaptor. No I'm attempting to remove the WSON8 from the mother board with my soldering heat gun... I've been at it for a while (putting heat for more then 8 minutes) and it is not coming out.
              I've did some google youtube search to see how to properly remove a WSON8 and could not find anything...
              Is it normal that it take a long time to heat up and remove it?
                • 21567
                8 minutes is a long time to heat the pcb.What model is your soldering heat gun and what temperature did you have it set to and did you use a nozzle
                • Korreia
                  • Sep 2021
                  • 14
                  I know, right...
                  This is the heat gun I have YIHUA 8786D
                  I've set it up to 580F ans yes I used a nozzle
                  noting was moving...
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    I know, right...
                    580 F is about 300C and is little low for unleaded solder, use max temperature and 3/4 air speed, the chip must be desoldeed in about 15-20 sec., if not check the hot air station. If you don't have enough experience, try to practice on faulty boards first.
                    • Korreia
                      • Sep 2021
                      • 14
                      Thanks for your help and support.
                      I ran my heat gun at 850 and that di the trick, it took +- 10 sec
                      • vinsun0399
                        • Aug 2019
                        • 38
                        • Jakulin
                        YIHUA 8786D - it always the best of choose , i think so
                        • Antix
                          • Aug 2025
                          • 4
                          • Portugal
                          Hello everyone. I was also trying to flash the BIOS with the clip connected directly to the motherboard, but as expected, NeoProgrammer did not detect it.
                          At a certain point the clip slipped, and it seemed to me that something might have popped off the motherboard.
                          When I tried to power on the laptop, it no longer turned on. Only the lights blink intermittently between yellow and white.
                          After checking, it looks like there should be a capacitor near the BIOS chip (see photo). Could it really be a missing capacitor? If so, which capacitor is it?
                          I also forgot to disconnect the CMOS battery—could that have caused an issue?
                          • peste
                            • Dec 2016
                            • 13312
                            • ROMANIA
                            I think it's a resistor...try between 35 ohms -50 ohms..
                            • Antix
                              • Aug 2025
                              • 4
                              • Portugal
                              Thanks, peste. Do you think it’s dangerous to put a wire and make a bridge instead of the resistor (which I don’t have) just to see if the laptop powers on?
                              • peste
                                • Dec 2016
                                • 13312
                                • ROMANIA
                                Do you have it from an old board? Don't you have a friend who can help you with a resistor? Go to a workshop and ask for an old board of any model you can find there.
                                • Antix
                                  • Aug 2025
                                  • 4
                                  • Portugal
                                  Hi peste, I connected it with a higher resistance and managed to turn on the laptop. Now I need to see if I can find a resistor that can be adapted.
                                  • Wutru
                                    HP Elitebook 820 G4 BIOS repair assistance required
                                    by Wutru
                                    Hi guys,
                                    If someone would be able to provide some expertise, I'd be very grateful.
                                    BIOS Corruption - Cause
                                    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                    09-06-2025, 10:32 AM
                                  • STKR123
                                    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                    by STKR123
                                    Greetings badcaps community,
                                    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                    I learned that desoldering...
                                    10-29-2024, 06:03 AM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Guest
                                    Elitebook 850 G5 BIOS bricked
                                    by Guest
                                    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                    I assume the BIOS update failed, so I searched for the BIOS chip.
                                    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                    Can the corrupted...
                                    03-24-2025, 01:21 AM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
