Re: Dell G5 15 5500 bios needed
Write your service tag.
My board hanging at bios screen; need to reflash bios bin.... kindly send me any working fileAttached FilesLeave a comment:
Hi I'm new here, need help, the original bios was lost, tried so many files and didn't work the best result that i have the laptop stays stucked at tpm screen and if i press F2 stay stucked on the bios scren, keyboard not responding, my laptop is a G3 3500 motherboard 19753-1 pcb selek n18eLeave a comment:
Re: please i need bios Dell G5 15 5500
backuphttps://www.badcaps.net/forum/attachment.php?attachmentid=274349&stc=1&d=1663787047Last edited by max7; 09-21-2022, 01:05 PM.Leave a comment:
Hello
Please unlock Dell Latitude 5500 for me. Information as follow:
- Motherboard version: LA-G902P
- Services tag: 2FF0PV2-8FC8
Thanks a lotAttached FilesLeave a comment:
hello friends..
another service has removed the bios chips before.so i can't access the original dumps. I flash bios from thus site but there is a start in manufacturin mode, and the service tag is not registered. Please help me with bios.
My ST - 59YX403
Express servise code - 11486759043Leave a comment:
try & feedbackAttached FilesLeave a comment:
selek_n18e_mb 18812_1 XGWOR$LA BIOS
DELL G3Leave a comment:
With this bios, there is a start in manufacturin mode, and the service tag is not registered. Can it be written down? ThanksLeave a comment:
st : 8k7tyz2
Please help me!Attached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by re1nholdHello Guys
I'm currently fixing two different Dell latitudes,
I need a E5550 BIOS - SERVICE TAG is: FSFB262
So far I flashed about 6 BIOS from this forum already,
none worked,
only fan spin ~3s, LCD black, keyboard LED on/off ok,
I tried manual extraction with scripts for ages so to speak. VM is untried yet.
This laptop is not burnt, it seems to just have a corrupted BIOS.
I extra baught ram. This has to work friends.
Do you generate it this way in Windows in CMD?:
Code:E5550A24.exe /writeromfile C:\bios.fd
by Aarush653Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
Worked good before failed flash now won't power at all.
May have been a bad connection.
Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
32mb chip - 25Q256JVEN
Attach Dell Bios Update file v1.14 - original Dell update...-
- Loading...
