Dell G5 15 5500 bios needed
  • amr soliman
    replied
    Originally posted by hoaca388
    Try older version.
    still the same no fans runing no screen capslook always on
  • hoaca388
    replied
    Originally posted by amr soliman
    i try it but fan no display and not working
    Try older version.
  • amr soliman
    replied
    Try
  • hoaca388
    replied
    hello every one
    i have dell g5 15 5500
    mainboard Selek g3 mlk n18p 19795-1
    Service Tag: 2LWMG63
    it had short circuit on gpu mosfet
    after replacing it came to life but stuck on logo
    tried whith to flash another ec.bin it worked but fan are very loud and it shut down after afew minute
    can any one fix my ec bios
    i uploded both ec and main
    best regards​
    Try
  • amr soliman
    replied
    hello every one
    best regards​
  • tonnum2
    replied
    Originally posted by qayyum786
    FOR MONTHS QUIT DELAY
    BUILD A COMPLEAT NEW BIOS YOU MAY TRY
    No problem
    when I use it bios on post 123
    - No fan speed 100%
    - Can save service tag
    - Can disable Manufacturing Mode active
    Now it's good working
  • tonnum2
    replied
    Forgot to attach Splitted file
    Now you may try
    turning on but black screen and fan speed full
  • qayyum786
    replied
    Originally posted by tonnum2
    How do I flash it? There's only one. not have 2 file 8mb and 16mb
    Now you may try
  • tonnum2
    replied
    Add service tag manually from bios setup save
    next boot press Alt+F to exit manufacturing mode
  • qayyum786
    replied
    it can not save svtg and fan full
  • tonnum2
    replied
    Originally posted by danito
    try
  • danito
    replied
    Help me, please
    my bios is corrupted and i use file bios on post #22
    my service tag is 32M0763
    and this is my original bios
    try
  • tonnum2
    replied
    Help me, please
    commented on 's reply
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • MK-1
    replied
    please can you provid a modified working bios and copy the service tag from the uploded old bios file
  • Oknarb
    replied
    Dell G5 15 5500
    Service Tag: 43DHG63​
    Thanks for replay, but the same.
  • hoaca388
    replied
    Originally posted by Oknarb
    Dell G5 15 5500
    The laptop does not display the logo when it turns on, it immediately goes into the system and it is not possible to enter the BIOS. Please clear ME. Thanks!
    ST: 43DHG63
    MB:19753-1
    Dell G5 15 5500
  • Oknarb
    replied
    Dell G5 15 5500
    ​ST: 43DHG63
    MB:19753-1
  • Dark Slayer
    replied
    Dell G5 15 5500
    Laptop stuck black screen turns on and off at max fan must remove battery to shut off cant access bios
    Service tag:JYJG203
  • Fabregasronaldsr
    replied
    Clean ME
    Tested. Same Issue
    All signal are present except PLT_RST#
    No CPU VCore PWR
    Fan Spins in full speed
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • 417731
    BIOS needed for Dell Vostro 3405
    by 417731
    Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
    Model: Dell Vostro 3405
    Tag:F0B1YF3
    CPU:Ryzen 3500U
    Thanks in advance
    07-06-2025, 06:48 PM
  • re1nhold
    Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
    by re1nhold
    Hello Guys
    I'm currently fixing two different Dell latitudes,
    I need a E5550 BIOS - SERVICE TAG is: FSFB262
    So far I flashed about 6 BIOS from this forum already,
    none worked,
    only fan spin ~3s, LCD black, keyboard LED on/off ok,
    I tried manual extraction with scripts for ages so to speak. VM is untried yet.
    This laptop is not burnt, it seems to just have a corrupted BIOS.
    I extra baught ram. This has to work friends.
    Do you generate it this way in Windows in CMD?:
    Code:
    E5550A24.exe /writeromfile C:\bios.fd
    07-18-2025, 09:18 AM
  • Aarush653
    Dell Latitude 5340 corrupt bios - clean bios needed
    by Aarush653
    Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
    Worked good before failed flash now won't power at all.
    May have been a bad connection.
    Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
    32mb chip - 25Q256JVEN
    Attach Dell Bios Update file v1.14 - original Dell update...
    10-14-2024, 04:28 PM
