HP 4410t Laptop Bios
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Hi Friends
    Need Bios for HP 4410t i have tried some only but not working. and after flashing am getting chip verification error in programmer. Please help
    Thank you
  • peste
    • 13436
    • ROMANIA
    Re: HP 4410t Laptop Bios
    Originally posted by sureshbobby
    Hi Friends
    Thank you
    post the backup copy of the original laptop bios
      • 21679
      Are you using a CH341A ?
      • Bloodhoundje
        by Bloodhoundje
        03-16-2024, 03:12 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • kenkaniff
        HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
        by kenkaniff
        Product Name: HP Pro x360 Fortis 11-inch G9
        System BIOS: U94 Ver.01.08.00 10/06/2023
        Serial Number: 5CG31946F5
        SKU Number: 85W05EC#AK8
        Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
        This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
        I needed to remove bios password...
        10-01-2025, 04:32 AM
      • Loli Popu
        DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 03:28 AM
