FPP55 LA-G07JP rev 2.0 bios dump
  • majee12
    • Jun 2021
    • 11
    • ghana
    #41
    Hi, has everyone bios bin for FPP55 LA-G07JP rev 2.0 bios?
    it turns on but no display and fan is in full speed.
    the sn:CND1024LD5
    • hoaca388
      Badcaps
      • Jan 2022
      • 12278
      #42
      the sn:CND1024LD5
      HP 255G7 Ath3020e 15 4GB/1T PC (203A8EA)
      Description : HP 255 G7
      Serial Number : CND1024LD5
      Product Number : 203A8EA
      Build ID : 19WW8WUT601#SBH5#DBH5
      Fearture byte : 3K3Q 6b7J 7M7W aBap aqar awbD bhcb dUdp dqfP jXm9 n3n4 .nn
      • majee12
        • Jun 2021
        • 11
        • ghana
        #43
        Thank you , i checked the laptop and the cpu was already dead . cpu power supply lines are all measuring 0 ohms
        • vuko
          • Feb 2015
          • 18
          • greece
          #44
          Originally posted by peste
          you have everything you need at post #4..085EA
          I try,but missing data and serial plus manifacture mode
          Please help to fix main orginal
          HP Notebook - 15-db1019nv
          S/N: CND9471NDV
          • peste
            • 13451
            • ROMANIA
            #45
            S/N: CND9471NDV
            at post #4 you also have the range where the DMI and KEYWIN information is located...
            the bios from post # 4..is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
            select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
            • DODYNHO12314
              • Sep 2024
              • CATANZARO
              #46
              bios fpv53-u64stn bios hp 255 g7
              S/N CND0160QCT
              • peste
                • 13451
                • ROMANIA
                #47
                S/N CND0160QCT
                post S/N, full name and model, motherboard model,product number,,etc.
                post the contents of the bios chip even if it is corrupted..
                • DODYNHO12314
                  • Sep 2024
                  • CATANZARO
                  #48
                  S/N CND0160QCT MODELLO 7DB74EA#ABZ HP 255 G7 SCHEDA MADRE HQ-TRE 71025 MODELLO 15-ac151nl
                  S/N CND0160QCT MODEL 7DB74EA#ABZ HP 255 G7 MOTHERBOARD HQ-TRE 71025 MODEL 15-ac151nl
                  in English please..
                  • peste
                    • 13451
                    • ROMANIA
                    #49
                    in English please..
                    The bios chip must be unsoldered from the board before writing or reading..
                    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                    solder wires between the programmer and the bios chip..
                    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
