help me mac pro a2338 bypass Activation
  • hani55
    • 100
    • morocco
    Please brothers, is there a solution to bypass ID Activation
    and thanks
  • d3b1ch
    • Sep 2022
    • Ukraine
    Re: help me mac pro a2338 bypass Activation
    Look into following thread — https://www.badcaps.net/forum/showthread.php?t=93978
    • kevingill
      Mac upgrading from Ventura to Sonoma with activation bypass
      by kevingill
      I've got a MacBook Air 2018 that was activation locked.
      I've used an online service to bypass the activation and was able to sign in to iCloud. If you power off the MacBook and restart, it will be activation locked again.
      However, I've just upgraded it from Ventura to Sonoma and after completion, the activation screen came up.
      To my surprise, this prompts for my Apple email ID and password.
      Once entered, the MacBook is fully activated and powering off and on works absolutely fine.
      Can someone else try this to see if it works for them too please?
      11-29-2023, 06:33 AM
    • harounHD
      Macbook a1989 and a2338 icloud bypass
      by harounHD
      Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
      02-01-2025, 03:23 AM
    • Siddig
      Help for A2338 M2-2022 Icloud activate bypass
      by Siddig
      Hi. I need Solutions to change serial number to bypass I cloud activate or serial address section in hexadecimal . Attached dump file.
      Model:MacBook pro 13" M2 -2022
      motherboard: 820-02773
      EMC 8162
      Serial number:WVK0329042....
      12-29-2023, 09:10 AM
    • Spudgun
      Why doesn't current just bypass faulty capacitors.
      by Spudgun
      Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
      04-01-2025, 10:33 AM
    • todordm
      Macbook A2338 / A2337 - Replace SSD
      by todordm
      There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
      01-17-2024, 03:55 AM
