Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
RCUnlocker
UnlockedSerial number:
5CD145JDLC
Product number:
1A893AV
i tried to flash the EC using the same model of laptop that i see in here, the only response is when i plug the charger the caps lock turns on about 5 seconds and after that the light goes off and when i flash and turn back the original back up SPI and EC rom it's the same response when i plug the charger the caps lock turns on about 5 seconds and after that the light goes off, not turning on pls need help...Attached FilesPremium supporters get full download access and other benefits.
Serial number:
5CD145JDLC
Product number:
1A893AV
i tried to flash the EC using the same model of laptop that i see in here, the only response is when i plug the charger the caps lock turns on about 5 seconds and after that the light goes off and when i flash and turn back the original back up SPI and EC rom it's the same response when i plug the charger the caps lock turns on about 5 seconds and after that the light goes off, not turning on pls need help...Leave a comment:
DAX8QMB28A0 Rev A
This Another 32mb is the SPI RomAttached FilesPremium supporters get full download access and other benefits.
Hello this is the bin of hp pro 450 G8 it has two 32mb bios chip
when i drag and drop to rc unlocker it say's "Wrong Chip try reading and unlocking 16mb chip"
this 32mb chip is ECAttached FilesPremium supporters get full download access and other benefits.
It say's " Wrong Chip. Try reading and unlocking 16mb chip"
HP Probook 450 G8 Power on Password issueLeave a comment:
HP ProBook 455 15.6 inch G9 Notebook PC
CT Number_6MFDP0KWYHU8SV
Serial_5CD3134Y1Y
Product_6H999AV
Build Id_22WWTPCZ601#SAB8#DAB8
Fearture byte_476J6S6b7B7J7M7Q7W7saBapaqauawbhcAfPguk8mEn7nWpnpqprqjqzr2r3.GDAttached FilesPremium supporters get full download access and other benefits.
hello everyone. I used the program but I couldn't do it. Can you help me remove my password?
HP ProBook 455 G9SN: 5CD3134Y1Y
These are the only thing I have look at the image.
That's why I'd ask if jumpering the pinouts directly will be also work? I'm afraid to damage the BIOS chip if I overheated the chip with hotair workingstation/blower. We are far from suppliers and other technicians if I damage the chip I can't find a replacement.Leave a comment:
the best thing is to remove the chip from the board, remove it with a blower, there are adapters for these chips, search in the software database and see which ones accept this chip..
I just want to ask if is it fine to read/dump bios without removing the bios from the motherboard? Like resoldering pinouts using jumper(magnetic) wire to programmer.
I am planning to reset or remove the bios admin password of HP 640 G9. The bios chip of this laptop is flat unlike other units that has spider pins and this I my first time repairing hp elitebooks bios.
I hope someone provided me a clear answer, I also would like to know what programmer is compatible for hp elitebook 640 G9 to read&write?Leave a comment:
you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
My 1st experiments with a cheap CH341A programmer + clamp + old hp EliteBooks.
The clamp is indeed pure horror at times and probably wont last very long.
But RCUnlocker works like a charme!
Thank you so much!
I am trying to remove the BIOS password from an HP 260 G2. I extracted the BIOS from the computer, but whenever I load it into RC UNLOCKER, the error "MISSING UNLOCKABLE CONTENT" appears.
I have tried for hours to overcome this issue and am at a loss as to where the problem might lie. Could someone give me a hint to guide me towards the origin of the problem so that I can overcome it?
Thank you.
Hi
i have 5 five mixed hp g9 and g10 elitebook
i want to remove password can any tell us how?
Share tools or teach what hex data we need change
thank you in advanceLeave a comment:
Hi, I am getting 'Missing Unlockable Content' when running RCUnlocker
HP ProBook x360 11 G5 EE
SN: TCDBGZWMA50OOI
MB ID: 6043B0273911 Rev: A01
Could not find support for w25q128jwpq in any programmer so used w25q128fw_1.8v.Attached FilesPremium supporters get full download access and other benefits.
you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDYHi,
First of all, thank you for the work done!
I have an HP EliteBook 830 G8 (ProdID: 6A3M6AV / SN: 5cg2145d1p).
I tried the software, but I got the following error message when launching: "Missing file destination argument!"
Is the software compatible with my PC please?
I also see that I will need to make a BIOS backup. Is this possible via software, or do I have to solder a module on the chip?
Thank you in advance
Thank you in advanceLeave a comment:
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
Channel: BIOS Requests ONLY!
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
- Loading...
