RCUnlocker
    Re: RCUnlocker
    Originally posted by paijoedanz View Post
    file to unlock
    What is your programmer - CH341a? What is the type of the connection between the chip and the programmer, are you using a clip?
    Your dump is not OK, read the chip again, use verification.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Re: RCUnlocker
      rt809f programmer.i have 2 same laptop using tool RC unlocker.
      you have any bios 840 g3 in fix me region ?
        Re: RCUnlocker
        Fixing the Elitebook 840 G3 ME region is completely off-topic here, and is not necessary in your case, just get a good dump from the chip as I said, and use the tool for unlock, that's it.
          Re: RCUnlocker
          oke thank you
            Re: RCUnlocker
            this
            Can you post the bios password asking picture !
              Re: RCUnlocker
              Hi All,
              Please need to unlock HP Zbook Firefly 14 G7, i used RCUnlocker to unlock 16MB chip, but password/fingerprint remain .. here the two files attached
                Re: RCUnlocker
                I have a locked ZBook 14 G7 (don't know the exact motherboard). I used a CH341A and AsProgrammer to read the W25Q256JV chip but it only generates 32mb files and RCUnlocker is asking for 16mb files. Does anyone know what I'm doing wrong? I'll attach the file anyway but I can't get it to work.
                  Re: RCUnlocker
                  Originally posted by badcri View Post
                  look for a 16MB chip on the board.. see on both sides..
                    Re: RCUnlocker
                    Yes , I found it on the other side of the board :P Thank you for suggesting it
                      Re: RCUnlocker
                      HELLO, HOW CAN I UNLOCK A Hp Zbook fury 17.3 G8.
                      It has 32 mb bios
                        Re: RCUnlocker
                        It has 32 mb bios
                        read this..
                        and post #1 in this thread...
                          Re: RCUnlocker
                          New hp models have both ec and bios 32 mb, why they are not supported? i see in the top that is supported
                            Re: RCUnlocker
                            please how can i used this RCUnlocker, because it gives me error while using it
                              Re: RCUnlocker
                              see post #1...what error?what laptop model?
                                Re: RCUnlocker
                                Hello. My HP 850 G5, after flashing the dump, gives a security device problem warning at startup. I read your post#607. Explain, please, how and with what to clear the VSS region. Thank you very much in advance.
                                  Re: RCUnlocker
                                  @evgenymgv
                                  Can you share your BEFORE and AFTER files? Assuming the unlock/patching wasn't properly performed.
                                    Re: RCUnlocker
                                    The situation is this: the laptop was working, the BIOS update was automatically downloaded. An error occurred during the update process. Laptop stopped turning on. A dump was downloaded from the forum, the ME region was cleared and flashed with a programmer. The laptop turned on, but there was a warning about a problem with the security device. Attached is the downloaded file.
                                    P.S. SPI chip 16Mb was erased before the dump was written
                                      Re: RCUnlocker
                                      you shouldn't erase the 16MB chip, this is why you have the security error
                                      you only have to reset the nvram on the 16MB chip
                                      attach the 16MB dump i will reset the nvram
                                        Re: RCUnlocker
                                        Yes, I know. The chip was erased before me, or rather, he just did not exist. I bought a laptop that no longer turns on. Therefore, unfortunately, I do not have a "native" 16mb dump.
                                          Re: RCUnlocker
                                          at what temperature should i set my heat gun? is 380 C enough and at what air speed?
                                          also, what speed should I read my chip using ezp2019+?
                                          should it be at 12 mhz, 6 mhz, or 3 mhz?
                                          Thank you for answering.
