RCUnlocker
+ More Options
Posts
  • maxitaxi
    • Jul 2021
    • 11
    • nedtherlands
    Re: RCUnlocker
    ok, can test it on thursday. 2 days off :-)
    • smiley60
      • Jul 2021
      • 43
      • UAE
      Re: RCUnlocker
      Originally posted by RethoricalCheese
      User error. Follow the instructions. You need 16MB chip modified, not 32MB.
      you mean patching the ec 16mb bios is enough for removing the password
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        Re: RCUnlocker
        Yes.
        • smiley60
          • Jul 2021
          • 43
          • UAE
          Re: RCUnlocker
          Yes.
          I m living at the world of locked bios laptops
          and want to check 9470m for now
          • Seattle2021
            • Jun 2021
            • 19
            Re: RCUnlocker
            Hi RethoricalCheese,
            Per your request, I am again attaching the BIOS for the 1040 G1 after multiple unsuccessful unsoldering and reprogramming using the HP Unlocker and RCUnlocker, as well using a BIOS downloaded from HP and modified lower portion of the bin file. Please let me know if you need additional information. Really appreciated for your help
            • RethoricalCheese
              • Mar 2013
              • 1518
              • Estonia
              #26
              Re: RCUnlocker
              Well, looks like programming issue. When you write, does verify pass aswell?
              • Seattle2021
                • Jun 2021
                • 19
                Re: RCUnlocker
                RhetoricalCheese,
                That's interesting and theres a possibility I have a faulty programmer. The post write verify always passed without any issues, I've even done a read after write, and the comparison were identical as well. I will continue to seek for a solution and may need a new software program. Thank you again for all your help.
                • maxitaxi
                  • Jul 2021
                  • 11
                  • nedtherlands
                  #28
                  Re: RCUnlocker
                  Yes, my bad. Used the wrong version of my tool
                  This is the one I meant to give you.
                  Hi , i tried the TEST_2 file but result is the same. I can press F10 and get message 'entering setup menu'. After 10 minutes i press F1 and i get 'enterin system information' so laptops seems alive but stays in the last-message-screen.
                  • ibo
                    • Oct 2019
                    • 93
                    • Turkiye
                    #29
                    Re: RCUnlocker
                    Wow very good tool thank you for this.
                    So this will also unlock HP G6 and G7 models?
                    and for this models i need to read the EC chip?
                    • Haker5
                      Banned
                      • Mar 2015
                      • 65
                      • internet
                      #30
                      Re: RCUnlocker
                      yes i sorted yesterday g6 all is working
                      • maxitaxi
                        • Jul 2021
                        • 11
                        • nedtherlands
                        #31
                        Re: RCUnlocker
                        i could send the laptop to you by DHL if that would help research ??
                        • LatinMcG
                          • Jun 2015
                          • 73
                          • USA/Puerto Rico
                          #32
                          Re: RCUnlocker
                          i have Patch 840 g6 32Mb patch file no need to patch 16Mb.
                          also Locked
                          both 32MB included to compare.
                          EDIT!!
                          Nevermind i was given bad INFO due to language
                          next post is working patch
                          • LatinMcG
                            • Jun 2015
                            • 73
                            • USA/Puerto Rico
                            #33
                            Re: RCUnlocker
                            here is a better example 830 G6.. seems its just changing the 3F to 3C on some areas to make it invalid.
                            then flash original back after the 16mb is forced to unlock without desoldering.
                            • LatinMcG
                              • Jun 2015
                              • 73
                              • USA/Puerto Rico
                              #34
                              Re: RCUnlocker
                              ok so this does work for 840 G6 32MB only... if you CleanME !
                              flash this then flash original after bios defaults and Security reset.
                              but 1 strange thing. notice $FPT goes was south to address 675000 strange..
                              so patch seems to be insert in the ME and descriptor is changed.
                              • RethoricalCheese
                                • Mar 2013
                                • 1518
                                • Estonia
                                #35
                                Re: RCUnlocker
                                It has been known for a while but I did not go for this path because it requires 2 soldering and 2 turning on.
                                Only advantage is that it's not needed to remove motherboard.
                                • przemek_79
                                  • Dec 2014
                                  • 28
                                  • Poland
                                  #36
                                  Re: RCUnlocker
                                  Great job thank you so much
                                  • LatinMcG
                                    • Jun 2015
                                    • 73
                                    • USA/Puerto Rico
                                    #37
                                    Re: RCUnlocker
                                    yes it does save time for clip users w good read write capability..
                                    one thing it cold use is cleanME first then drop on patcher to make it universal.
                                    maybe you could add a filename switch for hp like xxxx-HP32MB.bin ?
                                    would save some people time for multiple systems at same time
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1518
                                      • Estonia
                                      #38
                                      Re: RCUnlocker
                                      I'm going to enable 32MB in the future anyway. Might aswell try that. But not a priority for now.
                                      What clip do you use for wson chips anyway?
                                      • LatinMcG
                                        • Jun 2015
                                        • 73
                                        • USA/Puerto Rico
                                        #39
                                        Re: RCUnlocker
                                        wson chips . .add solder on sides of pad w wire.
                                        friend uses silicon that came w SVOD3
                                        i desolder w metal shield and low temp
                                        • LenBios
                                          • 122
                                          • Ker
                                          #40
                                          Re: RCUnlocker
                                          Hi RethoricalCheese;
                                          hp 840 G5 need only 32MB chip modified, or 16MB?
                                          Thank you
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
