RCUnlocker
Re: RCUnlocker
Originally posted by wildemo View PostHey.Sorry im new in that is this EC?Last edited by SMDFlea; 04-01-2023, 01:44 PM.
Become a Badcaps supporter
Thanks to all supporters.
Re: RCUnlocker
Originally posted by Udemzy View PostPls how can solve this issue,I've reinstalled the operating system, install a new vcruntime but I still get the same error message.
Originally posted by Stefax2001 View PostI already reinstalled Microsoft Visual C++ 2015 Redistributable, nothing has changed.Originally posted by Vesko356 View PostInstall both x32 and x64 files.Originally posted by Stefax2001 View PostThanks, it worked.----------------------------------------------------------------------------------------------------------------------------------------------------------
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Re: RCUnlocker
Originally posted by sadenki View PostHi, need help with HP G7 430 with power-on authentication, RCUnlocker won't take 32mb and 16mb work in software but password still present when power on.
Can someone give me a clueDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: RCUnlocker
Originally posted by peste View Postuse RCUnlocker only for the 16MB chip..the 32MB one remains the same..
Its not working, software take my 16MB dump, but when flash into IC laptop is still require password on power on :/
Here both version of 16MB dump (original and updated with RCUnlocker).Last edited by SMDFlea; 04-01-2023, 01:44 PM.
Re: RCUnlocker
Hello, i've been trying to get a dump of my bios using wson8 pogo pin probe and ch341a. After sticking the probe to the bios chip, the lights from the laptop powered on for a split second. After I assembled the laptop, POST error appears (is it because I removed CMOS battery? not sure) but the laptop boots fine. Now, do i need to disconnect all the connections from the board before using wson8 pogo pin probe or should I continue knowing the first scenario about laptop lights and possibly might short something?
And another problem, after I connected the battery, the laptop automatically powers on, is it normal?
Also after I put the back case, the caps lock stayed on for a few seconds and can only be booted by plugging the laptop from charger. Hopefully I did not damage my laptop.
Thank you for your help.Last edited by ogre4273; 09-25-2022, 03:00 PM.
Re: RCUnlocker
Originally posted by ogre4273 View PostHello, i've been trying to get a dump of my bios using wson8 pogo pin probe and ch341a. After sticking the probe to the bios chip, the lights from the laptop powered on for a split second. After I assembled the laptop, POST error appears (is it because I removed CMOS battery? not sure) but the laptop boots fine. Now, do i need to disconnect all the connections from the board before using wson8 pogo pin probe or should I continue knowing the first scenario about laptop lights and possibly might short something?
https://www.youtube.com/watch?v=DWWigscuQDYDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: RCUnlocker
Originally posted by peste View Postremove the bios chip from the motherboard before reading or writing the bios chip, don't use the probe otherwise you might have errors... if you don't have an adapter socket for bios chips stick the bios chip on the programmer, or wires between the chip and programmer.. the laptop starts without pressing the ON button because you removed the bios battery..
https://www.youtube.com/watch?v=DWWigscuQDYLast edited by ogre4273; 09-26-2022, 03:40 AM.
Re: RCUnlocker
So after some research, and as staded in my first post, the 32MB Main BIOS also need to be hex modify to be able to remove password on-power start.
I download couple of old and modify bit to understand what member modify, without succefully finding a method to remove it.
Can somebody lead me what should I modify to remove this dump "on-power password" that why customer don't set, and witch even HP with warrenty won't take it and ask ridiculous price to fix it ...
Re: RCUnlocker
Originally posted by Vesko356 View PostYou're welcome.
Yes, it is possible.
Maybe I do thing wrong, but same as Smiler, tool work and say unlocked, but power-on authentication is still there, can't acces bios to reset, so still stuck
Same laptop as Smiler, G7 830
Re: RCUnlocker
Can someone give me a clueLast edited by SMDFlea; 04-01-2023, 01:44 PM.I don't provide help for people using CH341A and a clip.
Re: RCUnlocker
Originally posted by DanielDacko View PostGive this a try, flash only 32MB file, leave the 16MB untouched. And leave feedback if it worked.
Edit : No need to reset security setting, boot into windows just fine
Thx a lot DanielDacko and RethoricalCheese for your awesome toolLast edited by sadenki; 09-30-2022, 07:48 AM.
Re: RCUnlocker
Originally posted by sadenki View PostFirst test, working fine, I don't want to reset security setting as I fear windows won't launch anymore, i gonna rebuild laptop and edit to tell if it boot into windows.
Thx a lot DanielDacko and RethoricalCheese for your awesome toolI don't provide help for people using CH341A and a clip.
Re: RCUnlocker
So I gonna flash again with you modify bios, reset security and default setting, clean SSD, make a clean install and I should be fine
Re: RCUnlocker
Originally posted by ogre4273 View PostCan I flash an older bios dump of the same laptop? because I updated the bios after saving and reading a dump.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
