RCUnlocker
  • Raiderman
    • Jun 2022
    • 18
    • U.S.A.
    #421
    Re: RCUnlocker
    Is there a way to dump the bios using software?
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #422
      Re: RCUnlocker
      No, sorry.
      Become a Badcaps supporter
      Thanks to all supporters.
      • Raiderman
        • Jun 2022
        • 18
        • U.S.A.
        #423
        Re: RCUnlocker
        Originally posted by SMDFlea
        Yes thats a WSON8 chip, don`t use the clip on that,you risk damaging the chip,shorting the surrounding components and cutting through traces.
        Your options are to desolder it,use a WSON8 pogo pin adapter,or try to solder some thin wires to the protruding solder or traces caps and resistors
        https://www.aliexpress.com/item/1005003313016522.html
        So that probe linked here is used in a similar fashion as the clip I already purchased? If so I will get it.
        6x8mm or 5x6mm?
        Its okay to still use the clip on the MXIC chip?
        *Nevermind, I ordered both sizes
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #424
          Re: RCUnlocker
          6x8mm or 5x6mm?
          According to the datasheet must be 8x6-mm.
          W25Q256JV is offered in an 8-pad WSON 8x6-mm (package code E), a 16-pin SOIC 300-mil (package
          code F) and two 24-ball 8x6-mm TFBGA (package code B & C) packages as shown in Figure 1a-c
          respectively. Package diagrams and dimensions are illustrated at the end of this datasheet.
          Looking at the photos of the ad, I have some doubts about the efficiency and the ease of use of these probes, but we will find out anyway when you get them. I hope they'll work well.
          • Raiderman
            • Jun 2022
            • 18
            • U.S.A.
            #425
            Re: RCUnlocker
            Thank you Vesko
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #426
              Re: RCUnlocker
              Thank you Vesko
              You're welcome.
              It's hard to answer - I forgot to take the crystal ball with me today.
              However, if you show pictures of both, I could try
              • Raiderman
                • Jun 2022
                • 18
                • U.S.A.
                #427
                Re: RCUnlocker
                You're welcome.
                Here is a pic
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #428
                  Re: RCUnlocker
                  Here is a pic
                  It's the same WSON 8 type spi chip as the other one, so you will be able to use the probes you ordered for both.
                  The clamps are used for the other type of spi chip which is called SOP8 or SOIC-8:
                  Here is a picture of the two types side by side for comparison:
                  • Raiderman
                    • Jun 2022
                    • 18
                    • U.S.A.
                    #429
                    Re: RCUnlocker
                    The one on the right is definitely like my windbond chip.
                    • NiHaoMike
                      • Jun 2022
                      Re: RCUnlocker
                      Would it be possible to run it on Linux? After extracting the archive, it appears to be based on Python and I assume would be trivial to port.
                      We believe in the right to repair.
                      • ryankou
                        Ryan @niway
                        • Oct 2016
                        • 38
                        • canada
                        #431
                        Re: RCUnlocker
                        anyone could help on this asus chromebox lock. Tried the program wont' unlock it. I have 5 of this with enrollment lock, any one could share the process of unlock. SN changed, still not working.
                        also attached unlocked bin won't work using the program.
                        • peste
                          • 13781
                          • ROMANIA
                          #432
                          Re: RCUnlocker
                          read post # 1 from this thread ..
                            • 22136
                            Re: RCUnlocker
                            You have already posted your request in the Desktop PC bios requests forum - https://www.badcaps.net/forum/showthread.php?p=1143579
                            This part of the forum is for laptop bios requests ONLY.
                            • ryankou
                              Ryan @niway
                              • Oct 2016
                              • 38
                              • canada
                              #434
                              Re: RCUnlocker
                              Sorry, didn't see the chromebox is supported. Thought they are the same.
                              • clrscr
                                • Dec 2020
                                • 186
                                • sing
                                #435
                                Re: RCUnlocker
                                RCUnlocker. not working. why? ( my laptop setup. window 10 64 bit)
                                show sms: Error 0xc00007b “Application was unable to start correctly”
                                every one help me!
                                thanks
                                all donations are welcome,
                                >>>>> click on this link to donate via PayPal. <<<<<
                                  • 22136
                                  Re: RCUnlocker
                                  Usage: Drag and drop .bin file to .exe file.
                                  • clrscr
                                    • Dec 2020
                                    • 186
                                    • sing
                                    #437
                                    Re: RCUnlocker
                                    yes, but tool not working >> show sms: Error 0xc00007b “Application was unable to start correctly”
                                    can you help me unlock!
                                    thanks!
                                      • 22136
                                      Re: RCUnlocker
                                      thanks!
                                      You have already posted your bios in another thread.....
                                      https://www.badcaps.net/forum/showthread.php?t=103652
                                      You MUST NOT:
                                        • 22136
                                        Re: RCUnlocker
                                        thanks!
                                        Search google for the error message "0xc00007b" ,theres a number of reasons why,such as youre tring to run the app on a 32bit OS, the .NET framework is corrupt or not latest version, and more results
                                        • clrscr
                                          • Dec 2020
                                          • 186
                                          • sing
                                          #440
                                          Re: RCUnlocker
                                          now it work, thanks!
                                          the software is compatible with HP Elitebook 840 G6. bios chip 32M. ?
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
