RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    RCUnlocker
    This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
    Unlocking
    HP - ProBook, EliteBook, ZBook (including 32MB models)
    Chromebooks from all various manufacturers
    Apple - everything older than T2
    More to come...
    Information display (helps to verify file integrity)
    HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
    Custom logo removal
    Usage: Drag and drop .bin file to .exe file.
    In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
    You may ask for feature requests, I'll see what I can do.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: RCUnlocker
    Looks like I should be the first to comment:
    Finally, the all new Swiss Army Knife style Unlocker tool is here.
    Keep up the good work!
    Become a Badcaps supporter
    Thanks to all supporters.
    • Stranged
      Stranged commented
      Editing a comment
      LOL TRUE😂😂😂😂😂😂
    • 31288
    Re: RCUnlocker
    if you release updates, please add version number to the filename.
    • Nico Latour
      Banned
      • Sep 2019
      • 52
      • france
      Re: RCUnlocker
      very great tool i test apple bin succed, hp old 16mb succed, but new elitebook 850 g6 fail he give error wrong chip size
      • Ghamidi
        • Mar 2020
        • 306
        • France
        Re: RCUnlocker
        Great job thank you so much
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Re: RCUnlocker
          User error. Follow the instructions. You need 16MB chip modified, not 32MB.
          • Conste
            • Oct 2018
            • 235
            Re: RCUnlocker
            What about toshiba? Do you see any possibility to unlock passwords?
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              Re: RCUnlocker
              Response codes aren't my thing. I don't have access to Toshiba servers aswell. Go ask evserv to publish it
              • Ghamidi
                • Mar 2020
                • 306
                • France
                Re: RCUnlocker
                Hi Mr RethoricalCheese
                the software is compatible with HP Elitebook 830 G6
                Thank you
                • maxitaxi
                  • Jul 2021
                  • 11
                  • nedtherlands
                  Re: RCUnlocker
                  i used the tool on a locked 850g6. Modified contents of u366 chip with unlocker-tool. Now, when turning on laptop, HP 'protected by surestart' appears and message does not dissapear. Does not pass bios-startup. If i press 'f9' also message 'entering setup menu' appears but message is still there afer 24 hours..
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    Re: RCUnlocker
                    Did you go into bios and reset security settings to factory default?
                    • maxitaxi
                      • Jul 2021
                      • 11
                      • nedtherlands
                      Re: RCUnlocker
                      i cannot enter bios settings. I press F10 during post , get the message 'Entering Setup Menu...' and stays there.
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        Re: RCUnlocker
                        Upload your original file. And try removing battery + clock battery for a few minutes, just in case.
                        • maxitaxi
                          • Jul 2021
                          • 11
                          • nedtherlands
                          Re: RCUnlocker
                          ok, i think i managed to upload the original contents
                          • maxitaxi
                            • Jul 2021
                            • 11
                            • nedtherlands
                            Re: RCUnlocker
                            battery + cmos battery removing does not help, i disconnected them before modifying u366
                            • smiley60
                              • Jul 2021
                              • 43
                              • UAE
                              Re: RCUnlocker
                              working on hp zbook 15 g2
                              thanks
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                Re: RCUnlocker
                                Try this instead.
                                • maxitaxi
                                  • Jul 2021
                                  • 11
                                  • nedtherlands
                                  Re: RCUnlocker
                                  Originally posted by RethoricalCheese
                                  Try this instead.
                                  This file is binary identical to the one that i put in the chip.
                                  I used your tool RCunlocker to edit the original file and have programmed that into the chip. The file you offered me no is identical according to filecompare , or do i miss something ?
                                  • dani981
                                    • Mar 2018
                                    • 89
                                    • Hungary
                                    Re: RCUnlocker
                                    Dear RethoricalCheese. Thank you very much, speeded up my work, worked well HP 840 G4
                                    Best regards Dani
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      Re: RCUnlocker
                                      Yes, my bad. Used the wrong version of my tool
                                      This is the one I meant to give you.
                                        HP Clean VSS2 dumps,fix Endpoint Security error
                                        by SMDFlea
                                        Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                        the infamous **"Endpoint Security" error message.
                                        Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                        I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                        The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                        files.
                                        hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                        filling everything after...
                                        08-08-2024, 03:14 PM
                                        HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                        This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-07-2024, 07:12 AM
                                        09-07-2024, 06:40 AM
                                        HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                        This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                        09-07-2024, 05:50 AM
