RCUnlocker
+ More Options
Posts
  • hoaca388
    Badcaps
    • Jan 2022
    • 12224
    #221
    Re: RCUnlocker
    Originally posted by stars-n-dust
    I have a BIOS file from HP x360 1040 G6 which needs password cleaning. Unlock tools are unable to clean it, anyone can help?
    Did you compare both files after running the unlock tool?
    • final_bad
      • Jan 2022
      • china
      #222
      Re: RCUnlocker
      Hi. I used the RCUnlocker tool, but still can't unlock the BIOS.
      Attached is the BIOS program for the hp 400 G7 that I exported with the programmer.
      The version is: S71 Ver 01.03.02 03/25/2020
      Can you please clear the corresponding BIOS password.
      Thank you so much!
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #223
        Re: RCUnlocker
        Originally posted by final_bad
        Hi. I used the RCUnlocker tool, but still can't unlock the BIOS....
        I don't think so. Attached to the message is the resulting file created by the tool.
        Become a Badcaps supporter
        Thanks to all supporters.
        • volinakis
          • Jan 2021
          • 2859
          • N/A
          #224
          Re: RCUnlocker
          I unlocked an 840 G6 using RCUnlocker, many thanks! After writing unlocked .bin file into BIOS and reset BIOS to factory default I had to make a firmware update to Intel Management Engine because CPU was limited to 0,33GHz and machine was running very slow.
          Off topic: reading messages here i saw many had problems reading correctly WSON BIOS chipsets and I want to share my way. I desolder BIOS chipset from motherboard and put it into clamps as in image. I also have an adapter for WSON but I often got bad results - chipset not rcognized, bad reading. With the clamp I have no such problems.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #225
            Re: RCUnlocker
            Originally posted by volinakis
            ...I also have an adapter for WSON but I often got bad results - chipset not rcognized, bad reading. With the clamp I have no such problems.
            Well, it depends on what type of adapter you are using for the purpose, I haven't had any problems with mine:
            • HUMDRUM
              • May 2012
              • 6
              Re: RCUnlocker
              RCunlocker
              says missing file destination argument
              hp unlocker won't even open, compatibility mode either.
              windows 11 pro 64 bit
              edit I need sleep says drop onto exe lol
              but RC unlocker still won't open
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                #227
                Re: RCUnlocker
                Wont open means what? There should still be some kind of an error.
                • HUMDRUM
                  • May 2012
                  • 6
                  Re: RCUnlocker
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #229
                    Re: RCUnlocker
                    So you did not drag and drop your .bin file to .exe file?
                    • HUMDRUM
                      • May 2012
                      • 6
                      Re: RCUnlocker
                      Also i need to unlock bios of this laptop
                      HP Notebook - 17-ca0014ds
                      AMD ryzen CPU, i tested with clean bios from hp it said unlocked
                      once I extract bios from the laptop this software should unlock correctly
                      I'm a newb at EEPROM stuff but I'm learning
                      • HUMDRUM
                        • May 2012
                        • 6
                        Re: RCUnlocker
                        correct but rc unlocker gives argument error
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #232
                          Re: RCUnlocker
                          What argument error? Give me full error message or a picture of it.
                          By the way, crap like HP Notebook is not supported right now. And they mostly tend to get unlocked using a code generator (insert wrong password or just press enter 3 times to get the code if it is not given straight away).
                          • HUMDRUM
                            • May 2012
                            • 6
                            Re: RCUnlocker
                            What argument error? Give me a full error message or a picture of it.
                            ill be back on at 9 am eastern Elitebook unlock needed I'm getting the hang of this now. and is this donation page correct
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #234
                              Re: RCUnlocker
                              Still seems like you did not drag and drop your .bin file to that .exe file. Instead you either just tried to open that .exe or you have some other issue like for example naming the .bin file in some idiotic way.
                              Like for example 840G1.locked.bin or 840G1 locked.bin is not a proper way to name a file. 840G1_locked.bin or 840G1locked.bin would be the way to do it.
                              • final_bad
                                • Jan 2022
                                • china
                                #235
                                Re: RCUnlocker
                                First of all thank you very much.
                                I used the RCUnlocker tool, which also generated the file provided by your attachment. After I flashed this file into the bios, when I turned it on, it still showed that I needed to enter the BIOS password.
                                I judged that the tool only generates a so-called unlocked file in name, and does not actually remove the BIOS password.
                                Maybe my operation is wrong.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #236
                                  Re: RCUnlocker
                                  No, your judgment is wrong. The tool works as it should.
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    #237
                                    Re: RCUnlocker
                                    So help us help you by giving more information. What model? Where are your files?
                                    • HUMDRUM
                                      • May 2012
                                      • 6
                                      Re: RCUnlocker
                                      I'm doing lots of research and getting better understanding of what is going on.
                                      Hp 840 G3
                                      Need computrace removal.
                                      I was told Ch341a would burn bios chip.
                                      Is there a way I can just replace chip and remove computrace,I only ask because I need to work on my solder skills a little more.
                                      Or would you recommend I use ch341a to read bin file?
                                      I'll do either , but what I'm trying to make sure if I just replace chips no more computrace?
                                      • slightly_delayed
                                        • Nov 2021
                                        • 11
                                        • NL
                                        #239
                                        Re: RCUnlocker
                                        Hi there!
                                        I'm trying to "desolder" a Macronix (MXIC) MX25L12873FZNI from a HP 820 G3 motherboard.
                                        Even after applying 30 secs of 500° C from a heat-gun I can't move or remove the IC (plastic around already melting).
                                        Could there be any other fixation like a glue or anything else?
                                        If any - how to get rid of this?
                                        • stars-n-dust
                                          • Apr 2019
                                          • 59
                                          Re: RCUnlocker
                                          Yes, files are different, but after installing the new EC chip, laptop won't power on.
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
