asus TP203NAH-BP046T
  • joeycuadr
    • Jul 2016
    • 4
    • phillipines
    pls help me I need dump Asus TP203NAH-BP046T bios
  • peste
    • Dec 2016
    • 13915
    • ROMANIA
    Re: asus TP203NAH-BP046T
    post the backup of the original bios and the full name and model of the laptop.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      https://www.asus.com/supportonly/TP2...HelpDesk_BIOS/
      Newest BIOS is Version 307, download ---> extract ---> cut (delete) block 0 - 7FF or select start-offset: 0 and length: 800 ---> save the rest of the file as *.bin and you'll have a bios file.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • joeycuadr
        • Jul 2016
        • 4
        • phillipines
        Thank you Vesko356 solve my problem 100 percent working your bios file for my Asus TP203NAH-BP046T
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • Sebastian Codrean
          BIOS file for ASUS F542UN laptop
          by Sebastian Codrean
          Hello to all of you! I need help with a BIOS file.
          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
          02-20-2025, 10:25 AM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • kodox
          Asus ExpertBook B1400CB Bios Dump Needed
          by kodox
          need original bios dump, original bios has flashed by other technician before me.
          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
          unit info:
          Model: Asus ExpertBook B1400CBA-0711A1235U
          S/N: R6NXNZ006657238
          CN: 7F6F
          Mainboard Code: B1500CBA R2.1...
          08-16-2025, 12:20 PM
