Lenovo ideapad 5-14IIL05 BIOS bin
https://www.badcaps.net/donate -
Re: Lenovo ideapad 5-14IIL05 BIOS bin
Sir I already attached my lapy model pic its may not l390 yoga I think right post here
Any one help me pls
I need build bios from my old attached ORg backupComment
Sorry, i was wrong.
Flex 5-14IIL05 Laptop (ideapad) - Type 81X1Attached Files↵
https://www.badcaps.net/donateComment
Hello, looking for Lenovo Ideapad 3-14ITL05 Intel Core i5-1135G7 bios, as mine has bios password pleaseComment
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
This is original bios
Don't have serial for this board as i bought it ebay to replace mine with burned gpuComment
Should be 128 not 64 ,and not OTP .Choose the chip manually don`t use Auto-Detect.What model is your programmer , an EZP2019 ?
.Last edited by SMDFlea; 11-09-2022, 10:58 PM.Comment
deapad 5-15IIL05 Laptop - Type 81YK
lc56-14t
203013-1
448.ok119.0011
orginal bios is no displayAttached FilesComment
That's why the device doesn't work, I don't know if the W25R256 is the original chip or not, I can send the original bios file of this model but it won't have DMI. You may have to replace the 32MB chip with a new one 16MB chip.Attached Files↵
Lenovo ideapad flex 5 14iil05
model 81x1
lc55-15c
19792-3
448.0k111.0031
original bios blinking power light
i already tested bin on post 10 some thingsAttached FilesComment
Is that what the chip has written on top,or is it what the programmer tells you it is ? ,if its the programmer then get the part number off the top of the chip and choose the chip manually in the programmer software, don`t use auto-detect. What model is your programmerComment
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... -
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
- Loading...
