need bios dump of dell latitude 5320
    Re: need bios dump of dell latitude 5320
    Hello, could use some help with unlocking Lat 5320 (6772GG3-8FC8), password locked and absolute active. Dump attached, thanks!
      Originally posted by mandrake87 View Post
      1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
      I have flashed the file, entered the service tag, but the absolute disable option is still greyed out when I try to disable it. Maybe I should disable it before entering the Service tag?
        UPD: somehow managed to do it by myself trough analysis of other locked dumps.
          prove
            prove
            Thank you. Everything is working. I have made a donation!
              Hi, could somebody unlock my bios for me, file has bios password.
              Thank you very much
                Thank you very much
                Read the RULES:
                You MUST:
                Read BIOS guides, methods, resources and tools
                Try the method at BIOS guides, methods, resources and tools before requesting help
                Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                Use search function in case someone already answered your request
                Post under a related thread if it exists
                Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                Name your thread with model numbers and request
                Provide a BIOS/EC dump if possible
                Attach files directly to your post instead of linking to external websites
                Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                all donations are welcome,
                  Sorry for problem.
                  Attched bios BIOS is working and have password. I tried to write other dumps from this tread but nothing works good, only like: starting lcd test display or nothing happend while pressing power on, only amber flash blinks. Details are as below:
                  DELL LATITUDE 5320
                  MB: 19817-1 SOUTH PEAK 13 10L
                  service tag: GKX83B3
                  once again Im attaching file
                  best regards
                    Sorry for problem.
                    DELL LATITUDE 5320
                    try
                      dell latitude 5320 . placa south peak 13 mb 213252-1
                      It has ABSOLUTE COMPUTRACE enabled, it won't let me disable it, can you help me please?
                      original bios file attached
                        Read post #207 ,the highlighted red text and -> https://www.badcaps.net/forum/showthread.php?t=103570
                          SORRY , dell latitude 5320
                          ST: 6378TG3
                            Hello try this file ....
                              thank you very much, it worked
                              I will try to donate something, very grateful
                                Originally posted by volinakis View Post
                                try
                                I had to replace chip from 25R256DYIG to 25Q256JVEQ
                                restarts couple of times and no power
                                shows blank screen for a while during one of restarts
                                  bios file for dell 5320 model south peak 13 Mb 213252-1
                                      HI every one i have dell 5320 not go to windows here is bios file st -FMZ9GG3 CAN eny one clean me for me
                                        Good morning, could you help me unlock this bios, it has an administrator password.
                                        Dell Latitude 5320
                                        Serial number: 34N1Z93
                                          Dell Latitude 5320
                                          Try this unlocked file ....
