need bios dump of dell latitude 5320
  • todenkopf
    • Oct 2014
    • 49
    • UA
    #201
    Re: need bios dump of dell latitude 5320
    Hello, could use some help with unlocking Lat 5320 (6772GG3-8FC8), password locked and absolute active. Dump attached, thanks!
    • user392097
      • Jun 2023
      • 11
      • Georgia
      #202
      Originally posted by mandrake87
      1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
      I have flashed the file, entered the service tag, but the absolute disable option is still greyed out when I try to disable it. Maybe I should disable it before entering the Service tag?
      • todenkopf
        • Oct 2014
        • 49
        • UA
        #203
        UPD: somehow managed to do it by myself trough analysis of other locked dumps.
        • mandrake87
          • Jun 2022
          • 70
          • argentina
          #204
          prove
          • user392097
            • Jun 2023
            • 11
            • Georgia
            #205
            prove
            Thank you. Everything is working. I have made a donation!
            • wwbielsko
              • Aug 2008
              • 59
              #206
              Hi, could somebody unlock my bios for me, file has bios password.
              Thank you very much
              • volinakis
                • Jan 2021
                • 2874
                • N/A
                #207
                Thank you very much
                Read the RULES:
                You MUST:
                Read BIOS guides, methods, resources and tools
                Try the method at BIOS guides, methods, resources and tools before requesting help
                Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                Use search function in case someone already answered your request
                Post under a related thread if it exists
                Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                Name your thread with model numbers and request
                Provide a BIOS/EC dump if possible
                Attach files directly to your post instead of linking to external websites
                Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                • wwbielsko
                  • Aug 2008
                  • 59
                  #208
                  Sorry for problem.
                  Attched bios BIOS is working and have password. I tried to write other dumps from this tread but nothing works good, only like: starting lcd test display or nothing happend while pressing power on, only amber flash blinks. Details are as below:
                  DELL LATITUDE 5320
                  MB: 19817-1 SOUTH PEAK 13 10L
                  service tag: GKX83B3
                  once again Im attaching file
                  best regards
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #209
                    Sorry for problem.
                    DELL LATITUDE 5320
                    try
                    • javier fajardo
                      • Sep 2021
                      • 69
                      • Colombia
                      #210
                      dell latitude 5320 . placa south peak 13 mb 213252-1
                      It has ABSOLUTE COMPUTRACE enabled, it won't let me disable it, can you help me please?
                      original bios file attached
                        • 22012
                        Read post #207 ,the highlighted red text and -> https://www.badcaps.net/forum/showthread.php?t=103570
                        • javier fajardo
                          • Sep 2021
                          • 69
                          • Colombia
                          #212
                          SORRY , dell latitude 5320
                          ST: 6378TG3
                          • Markus1741
                            • Sep 2020
                            • 956
                            • N/A
                            #213
                            Hello try this file ....
                            • javier fajardo
                              • Sep 2021
                              • 69
                              • Colombia
                              #214
                              thank you very much, it worked
                              I will try to donate something, very grateful
                              • wwbielsko
                                • Aug 2008
                                • 59
                                #215
                                Originally posted by volinakis
                                try
                                I had to replace chip from 25R256DYIG to 25Q256JVEQ
                                restarts couple of times and no power
                                shows blank screen for a while during one of restarts
                                • jacobs_matrix
                                  • Aug 2017
                                  • 15
                                  • algeria
                                  #216
                                  bios file for dell 5320 model south peak 13 Mb 213252-1
                                    • 22012
                                    • munir100
                                      • Dec 2018
                                      • 188
                                      • uae
                                      #218
                                      HI every one i have dell 5320 not go to windows here is bios file st -FMZ9GG3 CAN eny one clean me for me
                                      • johansel
                                        • Feb 2022
                                        • 39
                                        • colombia
                                        #219
                                        Good morning, could you help me unlock this bios, it has an administrator password.
                                        Dell Latitude 5320
                                        Serial number: 34N1Z93​
                                        • Markus1741
                                          • Sep 2020
                                          • 956
                                          • N/A
                                          #220
                                          Dell Latitude 5320
                                          Try this unlocked file ....
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5320 2in1 Hybrid (2-in-1) 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5320 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5320 2in1 boardview and 5320 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 03:40 AM
                                            DELL Latitude 5320 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5320 boardview and 5320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5320...
