plz help me dell precision m2800 vala0 la-9413p rev 1.0 a00 bios
  • toty_001
    • Nov 2018
    • 8
    • egypt
    plz i want bios file for dell precision m2800 vala0 la-9413p rev 1.0 a00 bios
    i have reprogramming bios with file from the same mother board but there is aproblem in gpu driver
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: plz help me dell precision m2800 vala0 la-9413p rev 1.0 a00 bios
    What exactly is the problem with the driver? I suppose the laptop freezes after installing the ATI driver, right?
    Become a Badcaps supporter
    Thanks to all supporters.
    • toty_001
      • Nov 2018
      • 8
      • egypt
      no the driver of ati amd fire pro not detected gpu
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Post your original bios backup.
        >>> You can try this confirmed working bios <<<
        • toty_001
          • Nov 2018
          • 8
          • egypt
          i have try this but the machine read as dell latitude e6540 in bios and windows
          but i want machine read precision m2800
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Is that so? Yeah, I want a Ferrari.
            If it works, what's the problem?
            Try:
            • toty_001
              • Nov 2018
              • 8
              • egypt
              Try:
              many thanks for you it work fine till now
              thanx
              thanx
              • niggi
                • May 2016
                • 191
                • UAE
                Try:
                thanks working file
                • robkom
                  • Jul 2022
                  • 19
                  • Poland
                  Hi.
                  Can anyone help me with this bios file? Old bios was broken, I found a new one. Everything would be ok, except that the laptop takes a long time to turn on. I guess it's ME's fault. Unfortunately, I can't clear ME.
                  Bios should have 9.0.31.1487 5MB - I have such a repsitory, unfortunately the program does not "see" it.
                  I've tried different ways - unfortunately I fell.
                  Can anyone help? Thanks in advance.
                  Dell Precision M2800
                  Board : VALA0 LA-9413P REV 1.0
                  • hardware1
                    • Sep 2021
                    • 2939
                    • N/A
                    Originally posted by robkom
                    Hi.
                    You should have another bios chip, it could be 4MB (32Mbit). you must combine both chips together before try to clean them, if you can't do it with your self, upload the other chip here.
                    all donations are welcome,
                    • robkom
                      • Jul 2022
                      • 19
                      • Poland
                      okay.
                      Thank you for the answer, I am including the file.
                      • hardware1
                        • Sep 2021
                        • 2939
                        • N/A
                        okay.
                        Try this one and let me know.
                        • robkom
                          • Jul 2022
                          • 19
                          • Poland
                          Sorry for the late reply - housework.
                          Everything works - it turns on immediately, without long waiting times.
                          Unfortunately, the keyboard does not work. Checked on two different keyboards. Early on bios without clean ME, the keyboard worked without a problem ...
                          Any suggestions?
                          • hardware1
                            • Sep 2021
                            • 2939
                            • N/A
                            Any suggestions?
                            Maybe it's a hardware issue, KBC (EC) as an example.
                            go there and tale your story.
                            https://www.badcaps.net/forum/forumdisplay.php?f=23
                            • robkom
                              • Jul 2022
                              • 19
                              • Poland
                              Welcome back.
                              I had a similar case with the Latitude 7240 - clean me, everything is almost ok but the keyboard is not working.
                              I did this: I took the same clean ME from the u52 file you sent, without moving u53, I put the extracted clean ME from you into the original u52 file (before you cleaned it).
                              I programmed the u52 chip with a new batch (your clean ME plus old u52) and everything works now.
                              And the funny thing is that I don't know why the keyboard didn't work before and now it works. It's important that my hunch on how to do it was right.
                              Thank you very much for your help.
                              Regards
                              • OKRPKCOMP
                                • Dec 2020
                                • 429
                                • PAKISTAN
                                Pls help, bios corrupted during bios updation Precision M2800
                                Service Tag: D4PLN32
                                Express Service Code: 28583035166
                                BOARD CODE: VALA0 LA-9411P REV 1.0 (A00)
                                BACKUP ATTACHED
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11815
                                BACKUP ATTACHED
                                Precision M2800
                                • OKRPKCOMP
                                  • Dec 2020
                                  • 429
                                  • PAKISTAN
                                  Thank you sir hoaca388
                                  display comes but screen devided in 3 parts. photo attached
                                  Laptop have Amd gharaphic, maybe bios is not compitible
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11815
                                    This doesn't seem to be related to the bios. Try exporting images via HDMI.
                                    • OKRPKCOMP
                                      • Dec 2020
                                      • 429
                                      • PAKISTAN
                                      ok sir thank you
                                      • trix11
                                        Dell Precision T1650 MT Workstation bricked after BIOS update
                                        by trix11
                                        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                        - Dell Precision T1650 mid tower Workstation
                                        - Xeon E3-1225 V2
                                        - 32Gb PC3-12800E RAM
                                        - 4Tb SATA HDD
                                        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                        I see now that others have experienced like issues e.g.:
                                        - https://www.dell.com/community/Prec...
                                        10-24-2022, 10:35 PM
                                      • federalhouse
                                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                        by federalhouse
                                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                        **Background:**
                                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                        **What I've Tried So Far:**
                                        1. I accessed
                                        08-01-2024, 07:03 PM
                                      • bmxlovah
                                        Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                                        by bmxlovah
                                        My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                                        11-24-2022, 06:29 AM
                                      • cozily
                                        DELL Precision 3660 Tower Workstation BIOS
                                        by cozily
                                        I bought a DELL Precision 3660 Tower Workstation from a second-hand seller. After bringing it home, I found out it was actually a testing unit. The BIOS cannot be upgraded (only the ME and PD2 sections are upgradable), and there are test messages displayed during boot, which really affects the user experience.
                                        Upon inspecting the motherboard, I noticed that the BIOS is composed of two chips: one 8-pin 16MB chip and one 16-pin 32MB chip.
                                        I acquired two new chips from another source containing the official BIOS version, but after installing them, I found that none of the...
                                        07-09-2025, 08:43 PM
                                      • toti24
                                        (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                                        by toti24
                                        dell precision m4600 laptop
                                        i7 2760qm
                                        8gb ram 750gb HDD
                                        intel hd 3000 integraded and nvidia quadro 2000m
                                        pleasea bear with me english isnt my language and ill try to be as clear as possible
                                        note i live in mexico in a very small town..
                                        thank you.
                                        laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                                        the brick happened when i was installing win 10 using usb.
                                        used rufus and officia microsoft.iso
                                        it finished copying files from usb...
                                        03-06-2022, 08:39 PM
