Trekstor Primebook U13b bios needed
  • nikolayu
    • Feb 2021
    • 37
    • tamo negde
    I need dump of Trekstor Primebook U13b bios.
    It uses ic MX25L4006E with AMI bios
    • 20673
    Re: Trekstor Primebook U13b bios needed
    Could be the EC as its only 512KB . Post the backup from that and the bios chip when you find it .
    • nikolayu
      • Feb 2021
      • 37
      • tamo negde
      Here is the backup of that
      • nikolayu
        • Feb 2021
        • 37
        • tamo negde
        Ok. I found the bios chip. It's GD25LB64C
          • 20673
          Thats it, post the backup .
          • nikolayu
            • Feb 2021
            • 37
            • tamo negde
            Here is bios backup
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Here is bios backup
              33.8 KB? Not a very good job
              Try again (harder).
              Become a Badcaps supporter
              Thanks to all supporters.​
              • nikolayu
                • Feb 2021
                • 37
                • tamo negde
                Here is harder
                Sorry i had bad pin connection to programmer
                • nikolayu
                  • Feb 2021
                  • 37
                  • tamo negde
                  Interesting thing that i noted. If i desolder BIOS and put in programmer it reads just fine.
                  But if i try to read BIOS directly from mother board with clamps (also i checked and clamps are making a good contact with all 8 pins) it reads wrong like the file that i sent you first time.
                  Could it be that BIOS is ok but something is "killing" it and because of that i get false reading?
                    • 20673
                    Here is harder
                    Try this bios .
                    • nikolayu
                      • Feb 2021
                      • 37
                      • tamo negde
                      The same problem. When i pres power button the pwr led just flash once.
                      (also 3v3 is present only when the pwr led flashes once)
