Legion 5 15IMH05 Bios
  • rewx5
    • Apr 2023
    • 5
    • Magyarország
    #41
    I have a Lenovo Legion 5 15IMH05 NM-C911 with i7-10750h and GTX1660Ti graphics.
    One of the mosfets for the 1660Ti GPU was shorted, so I have desoldered the Mosfets for the GPU and VRAM.
    Laptop boots to windows, but fans are on high speed, and shuts off shortly after.
    Could you please disable the 1660Ti in BIOS for me, so I can keep using the laptop with Intel graphics?
    Thank You!
    • peste
      peste commented
      Editing a comment
      post merged..
  • Tinkers1980
    • Jan 2025
    • 5
    #42
    Hi
    I have a Lenovo Legion 5 15IMH05H
    Serial PF2B6P45
    MTM: 81Y6005TUK
    It was doing a Lenovo system update in windows updates and it never turned back on, all I get is a blank screen.
    I have tried to read the bios and it is stored as lenovo old, and the latest bios from lenovo website is the efcn59ww
    is it possible someone can add the required info so I can try and flash it to get it working again
    Many thanks
    • hoaca388
      Badcaps
      • Jan 2022
      • 12423
      #43
      Originally posted by Tinkers1980
      Hi
      Serial PF2B6P45
      MTM: 81Y6005TUK
      Many thanks
      Read chip again , file's not good.
      • Tinkers1980
        • Jan 2025
        • 5
        #44
        I think I might have ended up trying to flash one I downloaded from Lenovo website and so not able to get the original one back, is there anyway to make one up from the one on their website and my serial number or do I need other information as well?
          • 22176
          Make another backup lets see whats on the chip. Are you using a clip ? , what part number is etched on top of the bios chip, what model is your programmer and software version, is the chip in the support list, did you use Auto-detect or manually select the chip.
          • Tinkers1980
            • Jan 2025
            • 5
            #46
            This is another one I tried to save but might have been after I had tried to flash
            • Tinkers1980
              • Jan 2025
              • 5
              #47
              I am using a clip on top with a ch341 programmer it is a 25b127, I have had to set as GD25Q127c in the one program or GD25G128 in a different program, this is what I have just read from it
              • Tinkers1980
                • Jan 2025
                • 5
                #48
                This is what the programs autodetect it as
ID:	3553821Click image for larger version
                • kamkooltech
                  kamkooltech
                  • Jun 2019
                  • 132
                  • nigeria
                  #49
                  A working bin for everyone
                  Lenovo Legion 5-15IMH05H OK
                  • Rolin
                    • Apr 2007
                    • 174
                    I have a Lenovo Legion 5 15IMH05H 81y6003yUS, Serial number PF2GN05C
                    It was working a couple days ago, put on the shelf. A few days later attempted to power up, no POST, keyboard lights up, fans spin for a little while then shuts off. I've already done the typical draining capacitance and removed CMOS battery,etc. No idea what happened, but I believe some Win11 updates were installing recently, but not sure if that was the last thing done on this laptop before failed.
                    Here is the bios, hoping it can be repaired or a new bios file to program. BTW: the chip is a winbond 25Q128JVSQ (but I chose winbond 25Q128JV on the programmer).
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12423
                      #51
                      Legion 5-15IMH05H (Lenovo) - Type 81Y6
                      • hardware1
                        • Sep 2021
                        • 2949
                        • N/A
                        #52
                        Here is your new file, it's a virgin BIOS from Lenovo with your DMI and Windows Key.
                        all donations are welcome,
                        • Rolin
                          • Apr 2007
                          • 174
                          Thanks Hardware1, I used your file to program the bios. All appeared to work well through neoprogrammer, I checked all items under "Write IC" (off protect, erase, blank check, write, verify) and it completed successfully. Tried to boot up the laptop, it turned on and off a few times I assuming auto calibrating to the hardware on the laptop, but the final cycle of the boot attempt and it did the same original issue and it turned off by itself (no display throughout). I tried to power on again, and the keyboard lights up, fans spin but no POST and shuts off in about 40 seconds. Same as before. Any suggestions from anyone? This is a pretty expensive motherboard.... but not looking too good right now.
                          • hardware1
                            • Sep 2021
                            • 2949
                            • N/A
                            #54
                            You're welcome. The file I sent should works fine, so most likely it's a hardware issue. Also you can try to change the BIOS chip itself, somethings it could be faulty but still can read/write it.
                            • Rolin
                              • Apr 2007
                              • 174
                              One more thing I just noticed. I noticed the caps lock LED will go on and off when pressed. But if it was actually running, not sure why it would just shut off in 40 seconds. And I've already tried an external monitor through the HDMI port several times to be sure (before and after the BIOS work).
                              • bakhanh
                                • Aug 2019
                                • 11
                                • Việt Nam
                                #56
                                Need Clean/Virgin Bios for Lenovo Legion 15-IMH05
                                I need a clean bios to flash to the bios chip.
                                Serial Number:PF30MCPC
                                Machine Type Model:82AU00PQVN
                                Legion 5-15IMH05
                                Mainboard: NM-C921 rev 1.0
                                Unfortanetely i dont have any old bios dump beceause someone wiped the bios chip. Laptop doesnt turn on right now so if someone can help me out with a clean bios.
                                Hope you guys can help me out.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12423
                                  #57
                                  Legion 5-15IMH05
                                  Legion 5-15IMH05 (Lenovo) - Type 82AU
                                  • bakhanh
                                    • Aug 2019
                                    • 11
                                    • Việt Nam
                                    #58
                                    no power.This bios file cannot be booted.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12423
                                      #59
                                      Find hardware problem .
                                      • bakhanh
                                        • Aug 2019
                                        • 11
                                        • Việt Nam
                                        #60
                                        I tried several other bios. some bios don't recognize the keyboard. some bios don't recognize the ssd... so I think the problem is still in the bios.
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
                                          Lenovo Legion 7 15IMH05 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion 7 15IMH05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7 15IMH05 boardview and 7 15IMH05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 04:30 AM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
