Da0g7dmb8d0 ec&bios
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Da0g7dmb8d0 ec&bios
    Hey guys, can someone please provide known good BIOS and EC for the following:
    Model: HP 13-an0002nf
    Board: DA0G7DMB8D0 REV
    Device came is with flashing caps lock (3 long and 2 short). Upon disassembly, it is very obvious someone else previously worked on the BIOS chip.
    I am not sure if the dump is any good since its showing as "configured" in ME analyzer instead of "Initialized" or maybe whoever worked on it before cleaned it. I tried cleaning ME nonetheless but no change.
    All voltages present except Vcore. I already checked for shorts and everything looks OK.
    Please find attached dumped BIOS.
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: Da0g7dmb8d0 ec&bios
    Originally posted by spider1211
    hey guys, can someone please provide known good bios and ec for the following:
    Model: Hp 13-an0002nf
    board: Da0g7dmb8d0 rev
    device came is with flashing caps lock (3 long and 2 short). Upon disassembly, it is very obvious someone else previously worked on the bios chip.
    I am not sure if the dump is any good since its showing as "configured" in me analyzer instead of "initialized" or maybe whoever worked on it before cleaned it. I tried cleaning me nonetheless but no change.
    All voltages present except vcore. I already checked for shorts and everything looks ok.
    Please find attached dumped bios.
    ok
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Thanks you for the file, but no change unfortunately. Still same flash sequence.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Anyone please?
        • snsui
          • 31
          • Argentina
          Originally posted by Spider1211
          Anyone please?
          look a slot and change Ram.
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            Its onboard RAM, not slot (not even present). Tried to reflow RAM chips but no luck. As per HP, 3 long & 2 short blinks is: "The embedded controller times out waiting for BIOS to return from memory initialization.".
            https://support.hp.com/emea_africa-e...ment/c01732674
            I'ld like to eliminate possible BIOS or EC issue before blaming the RAM chips.
            • snsui
              • 31
              • Argentina
              Its onboard RAM, not slot (not even present). Tried to reflow RAM chips but no luck. I read that 3 long & 2 short blinks is: "embedded controller has timed out waiting for the BIOS to return from system board initialization".
              if a have a black pads same error in rams or slot. now are dead, try.
              • Spider1211
                • Oct 2019
                • 532
                • Mauritius
                I did not understand, can you rephrase please. What do you by black pads? Do you mean the RAM chips (or some of them) are dead?
                  • 20918
                  Your original backup is from a HP 13-AN0020TU (same bios as the 13-an0002nf) ,it has some corruption,and because its still configured and not initialised would mean the board never posted far enough to read the bios chip properly because of the corruption,or for some other reason. Try another chip and the attached bios.
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    Thank you @SMDFlea but no change unfortunately, still same issue.
                    Edit:
                    Forgot to mention but with all BIOS I tried, screen can be seen to darken when power button is pressed.
                    • Romchik
                      • May 2017
                      • 6
                      • Ukraine
                      Hey guys, can someone please help me with BIOS for the following:
                      Model: HP 13-an0030wm
                      Board: DA0G7DMB8D0 REV: D
                      Device came is with flashing caps lock (3 long and 5 short).
                      I flashing the bios from another laptop, it starts, but works incorrectly, for a long time initialization and sound does not work.
                      I add the files of the original bios that does not work and the one that works incorrectly.
                      • hardware1
                        • Sep 2021
                        • 2930
                        • N/A
                        Here's your new file, try it and give me the results.
                        all donations are welcome,
                        • Romchik
                          • May 2017
                          • 6
                          • Ukraine
                          Sorry another 5 long and 3 short
                          • hardware1
                            • Sep 2021
                            • 2930
                            • N/A
                            Ok, try this one.
                            • Romchik
                              • May 2017
                              • 6
                              • Ukraine
                              Ok, try this one.
                              Hello, sorry yesterday the electricity was turned off, I couldn't try it.
                              Flashing laptop on after off, on and flashing caps lock (5 long and 3 short).
                              • peste
                                • Dec 2016
                                • 12819
                                • ROMANIA
                                bios extracted from HP site update..
                                DMI+KEYWIN 420000 - 42403F
                                • Suyadi
                                  • Feb 2022
                                  • Indonesia
                                  Please bios hp code board DAG7GMB48D0 REV
                                    • 20918
                                    Read https://www.badcaps.net/forum/troubl...before-posting ,post S/N ,backup etc .
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • Bloodhoundje
                                      HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                      by Bloodhoundje
                                      I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                      I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                      After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                      I have desoldered the bios chip (GigaDevice...
                                      03-16-2024, 03:12 PM
